Battery sensor
Old 02-01-2011, 12:51 PM
pauliehcfr's Avatar
Anyone know what the signs of a faulty intelligent battery sensor on a 2004 545 are? I think it might be bad, but want to be sure before I spend the money on it.
Old 02-02-2011, 01:41 AM
selbycy's Avatar
I am also interested in this.
Old 02-02-2011, 03:07 AM
frick's Avatar
IBS is a Intteligent battery sensor and he monitor SOC ( state of charge ) and SOH ( state of healt ) for you battery.If this sensor fail you give an error in DIS and your battery is not charged correctly by alternator.
Best regards!
Old 02-02-2011, 04:43 AM
pauliehcfr's Avatar
Heres the issue, when driving and changing gears, the interior lights will flicker, the sound on the radio cuts out for a second, and sometimes dynamic drive faults will pop up. If I disconnect the IBS, the problem goes away. I think the IBS is bad, but there are no faults stored. I am using carsoft to diagnose.
Old 02-02-2011, 05:46 AM
selbycy's Avatar
How do you disconnect the IBS, I might try that for a while.
Is there any side effects or potential problems from disconnecting it?
Old 02-02-2011, 08:24 AM
pauliehcfr's Avatar
go in the trunk to the battery. on the negative cable, you'll see a small black connector with a single wiring going to it. i think it's wire tied to the negative cable. i disconnected it and the problems went away. no check engine light came on nor did it seem to hurt driveability at all. it did store a fault but never set the check engine light on. its weird because when it gets warm, with the ibs still connected, i don't have this problem. its only when the weather is cold. keep me posted on what you come up with
Old 02-02-2011, 08:30 AM
gwf545's Avatar
My Ride: 2015 535D M Sport
Some times you have to wonder if there is such a thing as too much intelligence. How did we all deal with our stupid, non-IBS, batteries and charging systems for the past 100 years?
Old 02-15-2011, 02:19 AM
selbycy's Avatar
So this weekend my battery started playing up and I got the usual error messages, I disconnected the IBS on Saturday and have not had any issues so far.
Old 02-15-2011, 04:12 AM
luigi524td's Avatar
Curious, with your engine running what is the charging voltage at the battery terminals? (~ +/- 14V DC??)
Old 02-15-2011, 04:48 AM
selbycy's Avatar
I will check it out as soon as possible.
Quick Reply: Battery sensor
