Battery Safety Terminal?
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
My Ride: 2005 545i, Silber-grau/grau. Vanilla flavored except for cold WX pkg.
Banned
My Ride: A Car
guys, please install an OEM battery. If ur in california, have nomis_nehc register your battery afterwards. Spend the extra $50-$100 if necessary so you do not have problems. And if you need the battery safety terminal, get it replaced. It's there for a reason and might as well make everything look nice. It is a BMW at the end. No hack jobs allowed!
YOU DO NOT NEED TO USE AN OEM BATTERY. YOU DO NOT NEED TO REGISTER THE BATTERY.
The BST delete works fine.
My Ride: 2008 530i/2007 328i Coupe
I've been using a non-OEM battery for a year and haven't had a single issue.
Everything I have read in the repair manual, charging diagrams, and theory of operation show nothing OEM specific.
All the registration does is clear the 'learned' charging pattern. If you don't reset it, the charging circuit will re-map the charge rate slowly. The work around for that is to remove the IBS sensor for a few trips.
