Battery Replacing
My Ride: 550i
![Question](https://5series.net/forums/images/icons/icon5.gif)
I have a 2005 545I that needs battery replacing. Where can I find a replacement battery and avoid going to the dealer for Programming.
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
My Ride: 2005 545
Bought mine at auto zone too... no issues.. just make sure if u have a acid type,, stay with it,, and make sure to get the same characteristics as the original....
Same here no problems at all. 7 year warranty and dealer is only 2, go figure...
My Ride: 2006 BMW 535d M sport. Bi-Xenons, Auto Lights/Wipers, Electric Seats, 8.8" DVD Sat Nav, 6 CD changer, -think thats everything?!
Hey guys,
Just incase it helps - I've been through the process and thought I'd let you know...
2 parts to changing the battery over.
Registering the battery basically records in the system - at what point you changed the battery. i.e. 60,000 miles - 9/4/13.
Registering the battery is straight forward / done via DIS. Good if you intend of selling the car in the future.
I guess you could put a label on the top of the battery with the date/car mileage on it?
Good Luck with it.
- Programming/coding the new battery
- Registering the new battery.
Good Luck with it.
Autozone battery 3 years ago with no issues since, in 2005 545i. Cost about $100. No computer resetting either. If DIY, I recommend connecting another battery to the two posts under the hood to maintain your system settings. Just keep your polarity correct when connecting.
My Ride: 2008 550i M-Sport
I just bought mine from Pepboys. Bosch with the same characteristics. Two days later I had a check engine light and a day later I had Park distance control Malfuntion light. Both went away and no problems since. They had a rebate and my total was $100.
My Ride: Robin Reliant Running Chromes!
Hey guys,
Good Luck with it.
Good Luck with it.
Hi,
Some GREAT information here!
The logic of having to re-code/program a car for a dead battery is beyond belief, but this explains things well.. so Thank YOU!
