Battery problem
Old 02-23-2020, 02:38 PM
  #41
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Looks like the voltage regulator is doing its job.
Your 530 lives on, to die another day (ha-ha).
Old 02-23-2020, 06:17 PM
  #42
paneuro's Avatar
My Ride: 530D Touring M Sport manual
Default Battery problem
Yes I hope so, thanks for all your input and advice. cheers Paneuro
Old 02-24-2020, 10:32 AM
  #43
paneuro's Avatar
Hi Scott, on second thoughts I would rather it did not die at all, what do you know about 4 wheel alignment particularly the rear wheels, my adjustment seems to be seized, I don't want to snap the bolts. I have also heard that BMW don't supply the bushes on there own, you have to buy the complete arms and the price is eyewatering,.thanks Paneuro.
Old 02-24-2020, 11:19 AM
  #44
My Ride: 528i
Engine: N52k
I have not had to adjust my 5 series rear just yet.
I've seen the rear cam lobes operate for the rear adjustment.
Optimally, it would have been nice when your car was new or the rear was aligned well, to then put hash marks on the rear cam lobe adjustment (so it you ever took it apart you could return it to the measurement where you already knew it worked well).
Old 02-24-2020, 02:48 PM
  #45
paneuro's Avatar
Have you not had the problem of rear tyres wearing on the inside ? paneuro
Old 02-24-2020, 02:53 PM
  #46
paneuro's Avatar
If I knew how to put pics up on here I would let you see my winter tyres from last year! regqrds paneuro
Old 02-24-2020, 05:06 PM
  #47
My Ride: 528i
Engine: N52k
I have not seen any uneven wear on my rear tires.
When it comes to tires and brakes I'm overly protective.
- I rotate my tires every 5,000 miles
- I refresh the entire brake system each year with Pentosin LV Dot 4
- I change the brake pads every 1.5 years with newer technology that arrives in the market
Old 03-05-2020, 11:46 AM
  #48
paneuro's Avatar
Hi Scott, just to let you know everything has settled down and fingers crossed that I get no more problems with the electrics. thanks for everybodys help. Paneuro.
Paul Le Marechal
01-21-2014 07:16 AM
darnell moore
05-01-2013 10:27 AM
lcc014
10-31-2011 03:13 PM
daven
02-21-2009 11:52 PM
jjje28
12-06-2007 01:23 PM
Quick Reply: Battery problem
