Battery issue ..?
My Ride: 2015 435xi GC
Brought my 550i for service on Friday, my SA sent me on my way, and mentioned that my battery was low ( he said it was because "I dont take long trips", which isn't exactly true.. I suspect it has something to do with sleep-mode).
I told him that, on weekends, I regularly drive up North and he said "that should be more than enough," so I took a nice trip (~100mi) up here into the mountains.
Now,
When I hit the ignition button, I get a click'ing noise-- everything flashes once-- another click-- followed by a clock and an onslaught of errors:
or
And, I have no idea what to do.
I have a small battery charger here that I keep handy, connected it for a few hours, on the following settings (in bold) but nothing has changed
<Normal/Deep Cycle>
<Charge/Start>
<70AStart/12A(12v automatic)/2A(12v automatic)/12A(6v manual)>
Help?
The view up here is lovely, but I'm kinda stuck right now.
Now,
or
<Normal/Deep Cycle>
<Charge/Start>
Help?
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
You seem to have the charger set correctly based on your post. Have you tried the 70A start feature. i.e. will the car start? All the error messages are probably?? related to the battery. If it will start you may be able to get it home but your battery or alternator is probably toast. If the battery won't charge using the charger, the battery is probably gone. How old is it?
Thanks Gilgorm,
No I haven't tried the start feature yet, it's been sitting here, charging for approximately 3 hours now, and showing "70% complete" on my charger.
I bought my e60 in December, 2009.. and I'm questioning something; wouldn't my SA have notified me of a screwy alternator? He simply said 'battery's gettin' low, drive more or charge it'.. so I'm going to assume that this just needs a bit more time...
I want to disconnect the charger and give it a shot, but I can't get the saying out of my head: "patience is a virtue," "patience is a virtue," "patience is a virtue."
Unless it's evident that a car is driven fewer than 5-10 miles a day / 360 days a year, the Service Advisor auto-response = "You don't drive your car enough!" is a weak wrist excuse used to avoid BMW's problematic electrical system supply / demand & battery issue. Certainly if you drive only a few miles a day and then every weekend drive 100+ miles I would expect even a BMW to have an adequate electrical system to ensure the battery remains adequately charged.
It is more likely that some system malfunction is causing a steady discharge even after the car is put to rest. That often requires more diagnostic exercise than some SAs are willing to expend - thus, the easy (and lame) excuse, that you don't drive your car enough!
IMHO, you should push back (probably to the Service Manager) and have a proper diagnostician examine your car and correct all faults and NOT get in to the battery replacement ping-pong game.
BTW, there a rumor that BMW will not produce a hybrid vehicle ... seems they have been experiencing battery failure problems unless the vehicle is driven downhill with a 15 knot tailwind at least 74% of the time
With the last electrical 'issue' i had, the dealership ran a diagnostic on my electronics system and the report shows "no problems detected, to be re-verified"
Thanks Lui
Seems like it is a battery issue. How old is the battery? One should consider 2-3 years as a typical life-cycle of a battery. I had a similar situation as far as errors go- I was installing my rear cam and multimedia kit, for which had the doors open and closing for several hours while I worked on the vehicle. Interior lamps, trunk lamps, etc were on a lot and I did not drive the car in 3-4 days while I was working on this project. By the end of the 4th day, when i tried switching on my car, it hiccupped with a lot of clicking noises, flashing lights, lowbeams also flashed, and then got errors for- transmission failure; abs failure; brake disc failure; etc etc. I was scared shitless at one point. However, after jumping the car and charging it for a day at the dealership, I was good to go. So i would suggest you look into the age of your battery and how often this problem recurs. If it happens quite often then you may want to consider a change or battery test. I am assuming you have not added any aftermarket / satellite equipment into your car...
problem only seemed to be low/dead battery. i'm going to let it charge overnight and it should be top-shape by the morning.
i just wasnt expecting 15 error messages for a low battery
the battery is coming up on 2-3 years now, so if it is an issue of it being crap and unable to hold its charge, then i have no choice but to swap
DavaiLave
08-02-2022 02:16 AM
spitfire23
05-12-2015 04:23 AM
