Battery Draining
Engine: N54
Most likely is just a battery that isn't getting charged enough. The error message is more alarming than the actual problem - probably.
Charge up the battery as has been said. If it happens again shortly after, then you have a real problem either with a failing battery or an actual component that is drawing power when the car is off.
scalare
01-12-2010 09:55 AM
