Which battery can i buy instead of bmw 1
My Ride: 05" 545i 6 speed
i'd like to replace my battery, which i have no choice due to the car not starting at allll ! I turn the ignition then it starts coughing and turns off, now it wont start at all... just got the car last week. Upon reading some forums i see this is a common issue, not sure if something is draining it. BMW official battery is like $ 225 , i was wondering if i can buy one from autozone or etc.... but i do not know the exact dimensions because i dotn have the car now, my brother got stuck in another state, and he called bmw for assistance, wondering how much they'll charge ? so if anyone knwos exaclty what battery i can replace it with. thanks you
Model Year: 2005
Engine: 545i
My Ride: 2005 545 Silver Gray/ Beige, 6sp Manual, Sport, Nav, Comfort Seats
I have just had mine replaced under warranty. Check with your SA, and he should be able to take care of you.
Like you I have a 2005 545
If you're out of warranty I'd stick with a properly sized Exide or Interstate. The OEM Bosch batteries are middling performers at high prices. The correct batteries will have the vent top connections and terminals of the correct size.
You should verify that the battery "died" because it was "it's time" and that you don't have a charging system problem.
Ya... if you still have warranty have the dealer do it... I had mine replaced couple months back under warranty and they also did a fault scan to make sure nothing was draining the battery... Now car starts great with the new batt.
If you're interested I can post a PDF of a TIS article about these batteries.
My advice: Spend that little extra for the original battery.
My Ride: 2015 535D M Sport
Originally Posted by timewa' post='550612' date='Mar 25 2008, 04:51 PM
The high price is partly justified because BWM uses AGM batteries. Standard Pb batteries won't last as long and could even influence the electronics that measure the battery currents. There's quite some difference between batteries, you can't always just compare ratings and swap when it comes to modern high-tech cars like the E60.
I got mine replaced at the manhattan dealer in nyc for free. It was covered and i also have a 05 545i. Call you dealer and see what they tell you.
TroyE60
05-30-2019 05:01 PM
