Bapmic 6hp26 pan/filter
My Ride: Silver 07 550I E60 automatic
Engine: v8
Hell all, I was wandering if any of you have used this pan? I know I should have bought zf brand but I took the cheap route and now Question if the Bapmic brand is working properly. I changed mechatronics sleeve, 4 valve sleeves, bridge seal, and solenoids due to jerky shifting. After installing roughly 3.5 quarts of fluid I started the car to get that fluid circulation so I could add the next 3.5 quarts and the pan was still full. So the tranny if not pumping the new fluid. I'm questioning if the Bapmic pan uptake neck is sealing correctly. My car has the GA6HP26Z tranny
Engine: v8
I guess anything is worth a shot at this point but I thought the solenoids were only for shifting gear and assumed they play no role in the tranny circulating fluid with car running and in park?
e6t.lab.rat
02-13-2014 12:06 AM
