Backup camera
Old Jan 23, 2012 | 11:45 AM
BA535's Avatar
Hey guys I am new and have a question about an EAS backup camera I recently installed in my 08 535i. It is triggered off the backup light from the truck but does not activate every time. The system is looking for 12v to trigger and based on my volt meter that is supplied when the backup light comes on.
Old Jan 29, 2012 | 07:24 AM
neopoint's Avatar
You need to also install an automotive 4 pin relay 12V with reverse light power/ ground.
Good luck
Old Jan 29, 2012 | 07:52 AM
tonyb635's Avatar
Exactly, you can get the 12v trigger power from the brake light but I had the same problem. video was not acceptable... After installing the 4 pin relay allis perfect. It looks like the system needs 12v and the power from the light is not quite there. The relay will then send the 12v from your battery or where ever you decide to get it from.
Old Jan 29, 2012 | 02:18 PM
BA535's Avatar
Thanks I bought a relay at radio shack and it was easy to install. Works like a champ
Old Sep 3, 2012 | 08:23 AM
DBU's Avatar
DBU
It is not clear to me whether you are able to get the picture to show up on the iDrive screen? I have a MY 2007 (pre LCI) 530i. Is ther a DIY somewhere?
Thanks, guys.
Old Sep 3, 2012 | 09:24 AM
onetime's Avatar
My Ride: 2008 550i sport package
Neo and Tony, you two are some smart flippin' guys.
Old Sep 3, 2012 | 12:14 PM
tonyb635's Avatar
Not really, we just pretend to be... In my case the XCarlink guys told me to try it and if fixed my issue and also someone on the forum posted it too with an actual picture of the relay and connections.
