AWD AND DSC MALFUCTION!
Old Apr 22, 2010 | 02:20 PM
acampos's Avatar
My Ride: USE 2008 535xi with everything
Thank you for your help...for now the problem seems to have been resolved by moving the steering wheel right and left.
Old Apr 22, 2010 | 02:28 PM
chazmink's Avatar
My Ride: 2007 525xi, 6 spd MT, Tiefgruen, Nav, Traffic, Comfort Access, Sat Radio, iPodPremium/Cold WX Pkgs
Initially that worked for me but eventually I needed a permanent fix.
Good luck.
Old Apr 23, 2010 | 07:19 PM
acampos's Avatar
Good luck.
i need info in the permanent fix ??
Old Apr 23, 2010 | 07:23 PM
chazmink's Avatar
Earlier in the thread I summarized my experience. If you would like, tomorrow I can dig up the receipt, give you the part number and description of what was done. Please let me know.
Thanks.
Old Apr 23, 2010 | 07:56 PM
luigi524td's Avatar
Originally Posted by juris335
Ditto Chaz. I had the identical problem. Couldn't get it to go away on my 535xi. Dealer replaced the defective sensor on the steering column.
+1 ... Your dealer will likely find that sensor in the steering column will be out of spec. Happened on my '07 530xi when it was about 2 yrs old. Even though the warnings will go away for now they will come back and stay on. Take a phone pic next time and show your dealer's service adviser. When under warranty I don't suggest you try to DIY!
Old Apr 23, 2010 | 09:20 PM
bmwgroup's Avatar
Wait till you start having problems with your fuel pump. Got to love our N54's.
Old Apr 30, 2010 | 03:46 PM
acampos's Avatar
Thanks.
I would like the info' part number end description .thanks
Old Apr 30, 2010 | 05:06 PM
chazmink's Avatar
The invoice on mine says 27-10-7-546-671 Set Position Motor. The narrative says "Replaced Transfer Case Actuator." The fault was #52D4. I don't have any pricing since it was under warranty and everything is zero. As one of the other guys said, if your car is under warranty let the dealer fix it.
Old May 7, 2010 | 10:10 PM
rainmaker66's Avatar
My Ride: 2008 535xi Jet Black
Anyone knows what AWD and DSC Malfunction stands for....on my 535 XI BMW;I need info. in this Malfunction.
It is just software problem happens all the time. If it goes away no problem.
Old May 7, 2010 | 10:12 PM
FYI...N54 HPFP Fuel pumps warranty has been extended to 10 yrs 120k miles.
