Aux port or CD changer
Old 01-12-2013, 08:55 PM
  #21
ldesouza's Avatar
Originally Posted by bymer
Ah okay, bmw's cable should be even more straightforward as it should come with the tyco pins preinstalled, so yeah it should be plug and play behind the dash unit (cd drive).
Since you have everything coded via NCS, you are all set
I would first connect everything and hear the sound quality . (people reported back that it is missing bass, if it is too low for you, THEN you could consider removing the resistors, otherwise I wouldn't touch it )
Good luck and have fun
I got it to work!! The bmw did come with the pins installed but I did not have an empty slot. What I had to do was remove the pins from the cable and connect them to the existing connector that was already on my car and voila, worked like a charm. Ill post it on the thread i started on DIY section so it can help others in the future. https://5series.net/forums/diy-do-yo...4/#post1485594
So I did get to keep CD,NAV, AND MY AUX
Old 01-12-2013, 10:22 PM
  #22
bymer's Avatar
Good to hear, enjoy it
Vman33
03-14-2022 04:43 AM
CHRGRS_BMW
38
09-01-2016 09:39 AM
Wonky
04-12-2016 08:15 PM
bestofthebest
03-28-2016 02:47 PM
subieworx
09-21-2015 01:19 PM
Quick Reply: Aux port or CD changer
