AUX Input troubles
Originally Posted by shurick' post='430715' date='Jun 1 2007, 10:25 AM
Tried another brand new 3.5 mm cable.. same thing. I also noticed I'm hearing static feedback from the external Sirius radio when the light are on, turn signals on, or the brake pedal is pressed. If the device is not getting power from the car there is no such noise.
Originally Posted by pmmeke' post='430884' date='Jun 1 2007, 05:10 PM
amp is broken i think or the aux in is damaged and bad connection there
Originally Posted by shurick' post='430944' date='Jun 1 2007, 09:41 PM
gonna take a look at the connection behind the radio later... I think its the connector in the back, because otherewise everything appears to be working ok.
So i resoldered the "chip" back in place and found one of the pins for the AUX cable in the back of the wiring harness to be in the wrong spot. I brought the car back to the dealer, they changed the pin but I'm still getting the horrendous static feedback and loss of sound on driver side. Bringing the car back on tuesday to get checked out.. Any ideas what it may be?
bestofthebest
03-28-2016 02:47 PM
