Automatic Headlights
MARCUS545: I get this information from www.bmwtis.com. I pay for this service. However it is a valuable resource.
Tsandas: I will have to find the bulletin that stated it but it said end of June/earlyJuly. When I find it, I will post it.
GotBMW,
Any bulletins on Brake Force Display activation? It would mostly apply to EU spec cars built before December 2003.
Also any bulletins on noise coming from the engine? Posts on here suggest cause is due to Mechanical belt guide and is fixed by changing to a hydraulic guide.
My dealer is not getting anything useful from BMW UK. So it would be great if you have the bulletins, so I can taken them in to show them.
Thanks
Thanks
BMW530: I will check when I get home. I forgot my JumpDrive this morning. I was at my dealer last week Thursday. I stated I heard a noise from the engine si the tech and I took the car down the street, out of the noisy shop, and listen. He is a Master tech dealing with BMW's for over 15 years. There is no starnge noises from my engine. Basically, I never heard anything until I started reading about other poeple hearing noises and then sub-consciencly mine appeared.
Again, I will take a look when I get home and post whatever I find for you.
Cheers!
Cheers!
![Cool](https://5series.net/forums/images/smilies/imported/cool.gif)
Interesting thead. I noticed yesterday that my lights were on during the day when there was quite bright sunshine. It seems to happen if a change of direction suddenly shields the sun. I also agree that the angle of the sun in the sky effects when they switch on.
I do have one question, which is how long should the lights stay on for once the sensor detects their is suffient light available. Mine seem to be on for ages.
Thanks GotBMW for the tech bulletins. I will speak to my dealer and get my sensitivity adjusted.
Cheers,
Malc.
Cheers,
Malc.
Originally Posted by GotBMW' date='Jun 20 2004, 10:33 AM
Here is a Bulletin directly from BMW regarding this issue.
- Normal
- Sensitive
- Very sensitive
Also nothing in iDrive.
If the lights go on during the day, would the rear taillights affect other drivers?
I've stopped using the automatic feature, but think I might return to the auto feature and if the lights go on early, so be it.
So if I understand this correctly, if I want my switch to be less sensitive to light I have to set it to 'very sensitive'?? Meaning I want the lights to switch on as late (dark) as possible?
That's the way it reads to me as well. I understand from another thread that you can get a print out of all the car's current car/key memory settings at the dealer.
