Automatic Fans
My Ride: 2006 550i - Silver-Grey - Sprint Booster
Okay, this may sound like a silly question, but I need to ask. I recently found out about the two automatic air circulating timers in my car. Each timer lasts 30 minutes. I live in South Florida where it gets very hot and most times I get in my car it's even hotter inside. It can easily be 90 degrees outside, so inside is probably 100 or more I'd guess. Well, I thought I would start running the timed fans twice a day with the last one being just before I leave from work. It's not like it's running the AC, so the battery shouldn't drain much? Just concerned if I go on one of my weekly trips and forget they're set to run. Does anyone use this function? I assume BMW wouldn't include it if it wasn't safe.
My Ride: 2008 5351 Black Sapphire Metallic, Black Dakota Leather, Sirius, Sport Package
Thanks for the input, I thought it would turn on everyday, but that's good to know it won't. I tested mine and I knew it was set because the AC knob blink green or red I think.
There is third one, instant operation. It will start immediately for 30 mins.... Good when you just stop and get into shop to get something ....
BTW, if your battery is in good condition, it should not matter much. Maybe will reduce it life little bit due to extra charge/recharge cycle, but the feature is there meant for use. If you like it, just use it. I am in California, I use it a lot in my previous e39 and current e60. I don't feel any problem with Battery. For battery life in my previous e39....
first one: ( come with the new car ) ... 2 yrs.
second battery: (BMW oem, from US dealer) ... 4.5 yrs (still strong before I sold the car at 16.7K miles)
Same usage ... go figure. So each battery is different.
My Ride: 2008 BMW 550i
2006 BMW X3
I use the timer function in the summer. I usually set it to 4:30PM. It makes a difference. The above is correct, you do have to re-activate it each day. I'll have to re-learn the voice command I found to get to the menu but I seldom could get it to activate by voice. I think it was "parked car operation". Then simply checking the box activates it (IIRC).
Vman33
Mar 14, 2022 04:43 AM
ucsbwsr
Sep 19, 2015 10:58 AM
