AUC sensor still giving error after replacement
My Ride: E60 520i
Do you have any other errors? I had a blown fuse on my LCI, a fuse that runs AUC sensor, Grille flaps and some other option i cant remember...
Fuse location is inside the DME/DDE box under the pasenger pollen filter
elier (06-18-2023)
Probation Members
My Ride: bmw e60 full option
Hi.
My IHKA gives alarm 9C 54 64, I bought a new sensor and still I get the error, I then checked wiring and all 3 wires going to sensor is ok.
Also noticed problem with solar sensor(0x3d3) E720
IHKA is from E65 I believe had to upgrade to lci due to NBT retrofit.
Could there be something missing in programming?
BMW 520i E60 2004
BMW 520i E60 2004
![](https://cimg3.ibsrv.net/gimg/5series.net-vbulletin/903x1332/78c88d61_1442_4b32_bfcd_79698bbc607c_66bd6064f7e6fa9dbb801e639a8238e204493bc1.jpeg)
![](https://cimg4.ibsrv.net/gimg/5series.net-vbulletin/916x1165/ca3715aa_bac9_4833_ba91_38491e479fab_333bbfab4aca22987868303e3b657bd7b7431b17.jpeg)
My Ride: E60 Serie 5 - 530xd
Model Year: 2005.12
Engine: 3.0d
Hi guys !
I have the same pb about solar sensor(0x3d3) E720 after a NBT Retrofit on my Pre-LCI E60.
20210905_154018_FaultCodeDetails_VIN7-CP14746.pdf
I have carefully readen the post but I don't understand how do you fix the pb. On my pre-LCI E60, when I disconnect the blue connector from the IHKA, I haven't a wire on the PIN 2.
But when I have a look to the wiring diagram of Adv Ghaith Obeidat on PRE-LCI, there is a wire into this PIN.
So this is what I did : I took a +12V and connected it into the PIN 2 of the blue connector => no result, the error with RLS and solar sensor is ever here.
I don't know how supply in voltage the RLSS sensor (Rain/Light Sensor + Solar Sensor)
Someone for help me ?
Model Year: 2005.12
Engine: 3.0d
Hi girls and guys !
I have the same pb about solar sensor(0x3d3) E720.
But when I have a look to the wiring diagram of Adv Ghaith Obeidat on PRE-LCI there is a wire into this PIN.
So this is what I do : I took a +12V and connecte dit into the PIN 2 of the blue connector => no result, the error with RLS and solar sensor is ever here.
Model Year: 2005.12
Engine: 3.0d
In rerouting the PIN 2, Stian fixed the pb and its error E720 about solar sensor(0x3d3) disappeared.
So I suppose that if I do the same it will be fine for my case.
Model Year: 2005.12
Engine: 3.0d
But I don't understand how do you fix the pb. On my pre-LCI E60, when I disconnect the blue connector from the IHKA, I haven't a wire on the PIN 2.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It gets the power from the DME. Did you test to se if the sensor connector was getting power. It should be. That will tell you if it's a fault down the line or the sensor itself. I have an 05 pre-LCI and mine gets power from the DME. You may have a bad sensor
