Appears that dealer overtightened the front plate holder.
My Ride: 02/2006 525i Titanium Silver Metallic
Manual 6-Speed
Use a microfiber towel to dip in the cleaning solution and then scrub the headliner with a corner of that now damp towel. Next, use a dry wash cloth or terry cloth towel to dry and absorb the stain.
I didn't use a hair dryer, but you can use one to help the drying.
Good Luck
It's possible you can improve the deformation on your front bumper with a polished hammer and a heat gun. You have to be careful with the heat gun though, it could get too hot for the paint. Basically, you would slowly heat the area up with the heat gun and once heated well take the hammer and VERY gently and softly tap the area. You MUST go slow and take your time. If you get in a hurry its very easy to cause the material to go negative. The heat will soften the PP material and after you move it around a little and it cools it should stay. Again, you need to go very slow because the heat needs to saturate the material and not just be isolated to the surface. The heat gun should have a temp control on it and I would start with medium and max air. This is only another option for you. I would personally do this before you do any deburring.
Not sure I'm able to go that far.
Can I bother you with another question? When I look under the front bumper I see a black gasket that runs between the bumper and the the under carriage that's bent a bit. When I go to real OEM dot com I can't seem to find the part. It looks like it could be 3 on this photo, but there's no information on the site to explain that part.
Link to the page.
Is that actually the part I need and do you know what that's referred to as?
Photo of part:
ETA: Looks like I could just buy part number 15 and install that?
Link to the page.
Photo of part:
I tried adding a larger image of the original I posted to my Gallery, but it appears about the same size. You can see that the driver side screw sticks out a bit more than the passenger one, but I think when I deburr the hole I will get them to sit flush. The hair drier trick and some convincing may do the trick. I definitely don't want to mess it up any worse though.
ETA: I don't want to clutter up the board, do you have an opinion on what part I need to replace the lower bumper gasket I referenced? Seems like none of the parts show 09 528i on their compatibility. For $25 I may just buy the part number 15 pictured before and see if it goes on.
My Ride: '04 530. Black on Black
Black Grills
Tint
Ipod Retrofit June '10
Talk to your parts department about 15. I think that is the correct piece. As to the plates, I would get the bumper plugs, the screws look silly. I had the same problem, and took a knife to it to deburr it. I have jet black, so it was not that big a deal to take the knife to it. I went with black push plugs from home depot, they where cheaper, and way easier to get.
My Ride: 2007 550i (Sport, Prem, Nav, Logic7, Comf. Seats) Black on Black
Talk to the Sales Manager and the Service Manager where you purchased the car from and inform them of the issues that should have been addressed when they did their CPO checklist tobring the car up to par. They should agree to have YOUR local BMW address/fix some of the issues and then have them invoice them back. I was able to do this for mine.
I'll try the Woolite tomorrow.
I may try to primer and touch up paint some push plugs for the bumper, I need some touch up paint anyway.
