AOL Article on HPFP
For those that have not seen it yet. AOL did an article on the HPFP problem with the N54 engine. Let's see how BMW is going to react to this. I hope that they will take a proper action and finally come up with a solution to the problem.
http://www.dailyfinance.com/story/au...ompa/19560998/
My Ride: USE 2008 535xi with everything
perhaps mustafa550i is referring to the new F10 550i TT V8 model/engine...if so, then it's too early to tell, but that model has the same engine as the F01 and X5/6 .50, have not read of any hpfp problems as it's a different engine the N54. Even the I6 TT engine are no longer using the N54 engine, all have the N55 and again, have not read/heard of any hpfp problems....
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
