Anyone used a bottle jack to lift their E60
Hi all. I need to invest in a jack of some description, which is light and compact. This is only for changing the spare wheel in emergencies. A trolley jack does not fit the bill.
An OEM BMW one will be ideal, but BMW will charge me ??$$ for one. Now.........I can pick up a 2 ton bottle jack for about ?10 ($20).
http://www.tooled-up.com/Product.asp?PID=16150
My only concern is that I have never used one of these.
Also the one that I have seen is listed as requiring a minimum height of 181mm. I don't believe the clearance on the E60 allows this much space to physically get the jack underneath the jacking point.
All comments welcome.
Thanks guys.
Thanks guys.
My Ride: 2008 550I M Sport, Premium pkg, Logic 7, Sport Automatic Trans, Paddle Shifters, Nav, Comfort Access, Rear Shades, Satellite, PDC
Try out this site that I came across about using a floor jack with an attachment when I had an X5.
http://www.x5world.com/articles/x5/wheels/...-points-x5.html
I don't know standard lumber sizes in the UK, but I keep a couple of 2 foot long pieces of "2 x 10" (which is actually like 1 3/4 inches thick by about 9" wide). Just drive the car up on them and the jack will fit under just fine with the extra height.
Rather than a bottle jack for quick lifts like this I use a pair of small scissor jacks (can lift one side with a pair which is faster for wheel/tire swaps). Got these from when I had may E46 and they have always been great. Mine were from a Wal Mart store and only $20-25 each. Here's what mine look like -- even have a safety pin.
![](http://www.tradenote.net/images/users/000/119/841/products_images/Hydraulic_Scissor_Jack.jpg)
Rather than a bottle jack for quick lifts like this I use a pair of small scissor jacks (can lift one side with a pair which is faster for wheel/tire swaps). Got these from when I had may E46 and they have always been great. Mine were from a Wal Mart store and only $20-25 each. Here's what mine look like -- even have a safety pin.![](http://www.tradenote.net/images/users/000/119/841/products_images/Hydraulic_Scissor_Jack.jpg)
I'm really confused by this - surely the BMW scissor jack is similar to aftermarket ones, but then does it too only have a lift capacity of 1.5 tonnes ???
My Ride: Estoril Blue 440i GC
Model Year: 2017
How about a jack cheaper than a tenner??
Oh yes.
Go to your local scrappers and get a jack from a late model Vauxhall Carlton, or Omega and I think that the Cavalier/Vectra ones will be man enough too, but check the SWL - it will be printed on the jack. They come with a plastic top to nestle into the Vauxhall sill - take 2 minutes cutting the end lips off the plastic and it is a perfect fit for the BMW receptacle!
Remember that although your E60 weighs a lot, you won't be lifting its entire weight - probably only 65% of it, as for changing a wheel, you'll have two definitely on the ground, and the other mainly on the ground whilst you do it.
I've used my ex-Vauxhall jack with no problems, although I've never had a puncture on this car with non-RFT's on it. It's significantly smaller and lighter than a bottle jack too.
Cheapskate Mike
Oh yes.
Cheapskate Mike
If you are going to be hauling it around and space is an issue, a bottle jack may do the trick. It's probably OK if just for emergencies and if it will fit under the car (which will be extra low with a flat). I just find them a bit dodgy and unstable for my taste, but a scissor jack isn't that great either. I use a three ton floor jack in my garage and would just call AAA Roadside Assistance (not sure what the UK version is, but you get the idea) if I had a flat as they get paid to take that risk. Good luck.
Oh yes.
Cheapskate Mike
Oh yes.
Cheapskate Mike
A)
![Anyone used a bottle jack to lift their E60-2a6c_1.jpg](https://5series.net/forums/attachments/e60-discussion-2/57776d1482364712t-anyone-used-bottle-jack-lift-their-e60-2a6c_1.jpg)
![Cool](https://5series.net/forums/images/smilies/imported/cool.gif)
![Anyone used a bottle jack to lift their E60-f3d3_1.jpg](https://5series.net/forums/attachments/e60-discussion-2/57777d1482364712t-anyone-used-bottle-jack-lift-their-e60-f3d3_1.jpg)
C)
![Anyone used a bottle jack to lift their E60-d718_1.jpg](https://5series.net/forums/attachments/e60-discussion-2/57778d1482364712t-anyone-used-bottle-jack-lift-their-e60-d718_1.jpg)
