Anyone change a DISA on 545, 550, 745 etc
My Ride: 545i
Second time I got these 2 errors. Anyone change a DISA on a N62 or have had these errors before and fixed the problem?
Date: 21.11.2012 17:38:01 ECU: ME9N62 JobStatus: OKAY Variant: ME9N62-------------------------------------------------------------
RESULT: 2 error in error memory !-------------------------------------------------------------
2820 CDKDISA - Failure DISA
Error counter: 255 Logistic counter: 40
1. Umweltsatz Mileage 141752 km Engine temperature (tmot) 105.75 degrees C Engine speed (nmot) 760.00 /min Intake air temperature (tans) 21.75 degrees C Standard pedal angle (wped) 0.00 %
2. Umweltsatz Mileage 141752 km Engine temperature (tmot) 105.75 degrees C Engine speed (nmot) 760.00 /min Intake air temperature (tans) 21.75 degrees C Standard pedal angle (wped) 0.00 %
3. Umweltsatz Mileage 142552 km Engine temperature (tmot) 100.50 degrees C Engine speed (nmot) 960.00 /min Intake air temperature (tans) 12.75 degrees C Standard pedal angle (wped) 0.00 %
Signal or value above threshold Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Diagnostic active -- Cycle flag set -- -- Error in debounce phase
Error code: 28 20 21 25 00 00 FF 28 45 37 CD 13 5D 00 45 37 CD 13 5D 00 45 9B C6 18 51 00-------------------------------------------------------------
2821 CDKDISAT - DISA temp. warn level engine protection model
Error counter: 14 Logistic counter: 36
1. Umweltsatz Mileage 142360 km Engine temperature (tmot) 36.75 degrees C Engine speed (nmot) 760.00 /min Intake air temperature (tans) 3.75 degrees C Standard pedal angle (wped) 0.00 %
2. Umweltsatz Mileage 142400 km Engine temperature (tmot) 101.25 degrees C Engine speed (nmot) 760.00 /min Intake air temperature (tans) -0.75 degrees C Standard pedal angle (wped) 0.00 %
3. Umweltsatz Mileage 142512 km Engine temperature (tmot) 23.25 degrees C Engine speed (nmot) 720.00 /min Intake air temperature (tans) 5.25 degrees C Standard pedal angle (wped) 0.00 %
Signal or value below threshold Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Diagnostic active -- Cycle flag set -- -- Error in debounce phase
Error code: 28 21 22 25 00 00 0E 24 45 83 71 13 45 00 45 88 C7 13 3F 00 45 96 5F 12 47 00 ================================================== ===========
My Ride: 545i
After searching for a while I came up with a link in the 7-series forum.
Ongoing Disa issue N62 engine - Bimmerfest - BMW Forums
Looks like the gears inside the intake manifold on the n62's get gummed up and put stress on the disa motor. Throwing these codes. I think after Christmas I'll try to split the manifold and clean it out. If I get around to it I'll post a DIY.
Good find. I think people overlook this stuff until they are desperate and then there is no info out there about it to reference. Looking forward to your DIY.
