Anyone with a 535XI running on 19's or 20's?
Old 03-09-2008, 04:02 PM
  #21
C's Bimmer's Avatar
Too bad these don't come in a wider rear for staggered.
Old 03-09-2008, 05:17 PM
  #22
BlaSTiWi's Avatar
D.
It was my first impression too when I looked around last summer then contacted ALT Wheels while checking 'bout the weight, offset & hub size they said the offset was a typo... and I checked the back of the front set it has ET35 printed on it. Maybe I'll take some side view pics later...
R.
Originally Posted by DrLev99' post='542051' date='Mar 9 2008, 05:51 PM
I am looking at Bekkers website and it is showing the Miro 346 19" is available in ET38, not ET35 like you say. I might have gotten these myself had I known about them prior to my CSL purchase...grass always greener....
http://www.bekkers.com/Merchant2/merchant....;Category_Code=
Old 03-09-2008, 05:19 PM
  #23
BlaSTiWi's Avatar
C.
You mean the Miro? Mine is staggered setup w/ the exact same size as yours just w/ slightly smaller offsets.
R.
Old 03-09-2008, 05:45 PM
  #24
brozboril's Avatar
DrLev99 - Did go with the Generals.
Wheels, Tires, Mount, and Balance shipped for $1650....Had the Mkit, Hoen's, and M trunk finisher also installed last week so it is probably time to post some pics. Thanks for all the help with info that both you and C have provided. The car really looks a lot better.
Old 03-09-2008, 07:33 PM
  #25
DrLev99's Avatar
For my tires, check my signature. Now get on those pics! Did you get the H&R's on also?
Old 03-09-2008, 07:34 PM
  #26
DrLev99's Avatar
Hey C,
It appears they do.....
Old 03-10-2008, 08:30 AM
  #27
BlaSTiWi's Avatar
OK, here are the low angle side view pics (sorry the car is rather dirty):
Looking toward the front from the rear right:
Rear spec = 9.5" x 19" - ET40 w/ 275/30-19 GE-UHP @ +/- 50 lbs
Looking toward the back from the front left:
Front spec = 8.5" x 19" - ET35 w/ 245/35-19 GE-UHP @ +/- 48 lbs
Old 03-11-2008, 07:53 AM
  #28
too solid's Avatar
My Ride: 2009 Ford F-250 Harley Davidson Edition 6.4L OHV Power Stroke Turbo Diesel V8 (350hp/650lbft) Blue Flame Package Dual Alternators Touch Screen Navigation + DVD Player Uplifter Switches Trailer Brake Controller Traction Control Rapid Heat Supplemental Cab Heater Rear View Camera Power Slide Moonroof
I've made up my mind and want to go with 20" Miro 346's staggered set up. Bekkers.com dosn't have the 20"s with the right ET for my XI. Does anyone know where I can find them? They must ship to Canada. If I can't find the 20"s I'm going to go with the 19"s.
http://cgi.ebay.com/ebaymotors/19-BMW-E90-...43078QQtcZphoto
Old 03-11-2008, 08:26 AM
  #29
BlaSTiWi's Avatar
AFAIK Miro 346 in 20" only available in low offset setup for the RWD cars I think ET20/25...
If you sticking w/ 20" you might wanna try Miro 347 instead that has proper high offset for the XI I think ET40/38 but if I remember correctly in staggered setup the front is 'bout 10 lbs and the rear 'bout 13 lbs heavier than Miro 346.
Also, make sure you're gettin' the right tire size from the link you got it's good for E90 (3-series) as you notice the site title, I think for ours the wider tire size add the cost:
http://cgi.ebay.com/ebaymotors/19-BMW-E39-...05427QQtcZphoto
but w/ the RWD offset so you need to mix-n'-match w/ that seller and also don't forget to add TPM sensors or swap w/ the ones from your current setup.
Old 03-11-2008, 08:33 AM
  #30
C's Bimmer's Avatar
I would go with the 19's for this particular wheel.
Next up....lowering springs!
Quick Reply: Anyone with a 535XI running on 19's or 20's?
