Anybody get a wheel alignment yet.
Old Sep 18, 2005 | 06:02 PM
pennetta's Avatar
I hit a big pothole and very slightly dented the inside of the rim. I am going to send her in for an alignment, anybody have any problems with it?
Old Sep 18, 2005 | 07:51 PM
ipse dixit's Avatar
[snapback]172159[/snapback]
Are you sure you need an alignment? Running over potholes usually won't knock the alignment out of whack.
Check the alignment yourself before sending her in --- drive on a flat road and let go of the steering wheel and see if the car veers in any one particular direction (also take note of the crown on the road, which may cause the car to veer in one particular direction, usually to the right).
There is nothing particularly noteworthy or difficult about the E60 alignment. Just ask for a 4-wheel alignment, which can run anywere from $60-100 and take up to 1 hour or so.
Good luck.
Old Sep 18, 2005 | 09:06 PM
norham's Avatar
My Ride: 2004 520i, mystic blue, steptronic, beige leather, pdc, bluetooth, rain sensor, BMW sport kit fitted, 18" 166 rep BMW rims , de-badged, cherished reg. chrome grill,
Originally Posted by ipse dixit' date='Sep 19 2005, 04:51 AM
[quote name='pennetta' date='Sep 18 2005, 07:02 PM']I hit a big pothole and very slightly dented the inside of the rim. I am going to send her in for an alignment, anybody have any problems with it?
Good luck.
[snapback]172200[/snapback]
[/quote]
Wow what aprice glad I live in the UK its about ?10/ ?15 using lasers and why would you get all 4 done??
If the car has been lowered then it should be done afer about 500mls
Old Sep 19, 2005 | 06:08 AM
pennetta's Avatar
Good luck.
[/quote]
At $1800 per set of tires $100 for a wheel alignment is not bad. I have run over a few potholes, that sounded horrible because of the low profile wheels.
Old Sep 19, 2005 | 06:22 AM
RAI's Avatar
RAI
If you have active steering, an alignment is considerably more complicated and should ONLY be handled by a dealer. Do not take it anywhere else if you have active steering.
Old Sep 19, 2005 | 06:30 AM
BetterMakeWay's Avatar
Originally Posted by RAI' date='Sep 19 2005, 09:22 AM
If you have active steering, an alignment is considerably more complicated and should ONLY be handled by a dealer.? Do not take it anywhere else if you have active steering.
[snapback]172308[/snapback]
One other reason i didn't buy the AS! Here it is even difficult to get a wheel alignment and to make it as new.
Old Sep 19, 2005 | 06:33 AM
realtyman's Avatar
My Ride: Now Driving a Freakin' Prius! Was... 2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
I had two alignments (one with each steering rack). My SA told me that they are quite difficult. (The first one took a while as they didn't have the specs in yet for the Hunter machine).
I'd only have an alignment done at the dealer with cars that have Active Steering.
Old Sep 19, 2005 | 06:49 AM
Tuga's Avatar
My Ride: 2001 BMW 316ti, 2004 BMW 530d, 2006 BMW 530xd, 2013 BMW 320d touring, 2014 BMW 520d touring, 2016 BMW X5, 2020 BMW 320da touring, 2020 BMW 540i
Model Year: 1974
Engine: Flat six
I got 3 alignments until the moment.
The second one was no good, the car will start trembling .....
After the 3 rd everything just fine.
Old Sep 19, 2005 | 08:14 AM
pennetta's Avatar
Thanks, Its going to the dealer on Friday.
Old Sep 20, 2005 | 11:02 AM
norham's Avatar
[snapback]172324[/snapback]
I wouldn't be so sure the alignment caused the trembling INMO alignment only shows in the uneven tyre wear
