Any way to crank the engine without starting it?
Hopefully someone can help me figure out if it's possible to do this. My car has been sitting in the garage for 2 months while I was away from home, and I would like to avoid starting it "dry" with all the oil drained back into the pan. I want to turn the engine over for a few seconds before starting it so some oil pressure can build. I know on some other cars there is a trick to hold down the accelerator before starting, but don't want to try this with a push-button ignition unless I am 100% sure it works. I hope there is a similar trick for the E60 written somewhere that someone knows, perhaps in a service manual... thanks in advance.
thesalboy
04-08-2015 09:13 AM
