Any suggestions
Old 09-29-2009, 08:16 AM
bmwroger1's Avatar
My Ride: 2004 BMW 545I M sport suspension Active Steering M sport interior Navi Low ride sports
sorry to hear that bro...i had the same issue... when i had bought my car from a used car dealer i had taken the car to my mechanic to check it out before i bought it...everythings was in perfect condition but i had come to the conclusin that there were 3 cracked rims only one was leaking the rest were cracked and throughout time they would eventually leak. long story short the dealer finally got me 4 of the exact same rims, used but good condition. apparently this is common with oem factory rims from bmw. not only on 5 series but the 3 also... im sure of the 1,6,or 7 series.
Old 09-29-2009, 01:58 PM
LJTX545I's Avatar
My Ride: 2005 BMW 545i, Titanium Silver. Bridgestone 760s on Weds Bavaria II 18" wheels, standard sport pack size. Sport, AT. Latest job - NGK Iridium IX plugs installed.
I think the best solution is to go with smaller rims and higher profile tires. That will also be easier on the wallet as well. Got the same problems around here with potholes. Hope you find a suitable solution.
Old 09-29-2009, 02:31 PM
SpookyJohn's Avatar
My Ride: 2006 BMW 550i * SMG * Sport * Premium * Cold * Nav * Logic 7 * 6-Disc * HUD * Comfort Seats * Sprint Booster * M-Tech Body Kit * 20" AC Schnitzer Type III Racing Wheels * Black Out Front Grille * Black/Silver Carbon Fiber Roundels * AC Schnitzer Trunk/Roof Spoilers * AC Schnitzer Billet Pedals
I run 20" ACS wheels. I hit a pothole going pretty dang fast and cracked one, it was $100 to have it welded.
Old 09-29-2009, 03:29 PM
mnmike's Avatar
My Ride: 545i/6spd
What model car and which wheels do you have?
What do you inflate your tires to?
I'd like to think in MN we have some of the worst roads and I've never cracked a BMW wheel (knock on wood)
Old 09-29-2009, 05:28 PM
mhs525's Avatar
I have had good luck with BBS. CH's on my E39 and LM's on my E60. Never a bend or crack and they ride very well.
Roads up here in MA are pretty bad...
I do however also run pretty small wheels considering what some people use. I had 17's on my E39 and I use 18's on my E60 which gives me enough sidewall for the tire to absorb most impacts.
Old 09-30-2009, 02:34 PM
WSTO's Avatar
You should be able to run a 19" or 20" high quality wheel with no problems. Preferably forged. I suggest Volk personally for their styling, quality, strength, and weight. Alloy Technic is also a great high strength forged wheel!
Shoot me a PM if you have any questions
Old 09-30-2009, 02:37 PM
Kzang's Avatar
OEM 18" wheel on a sports package on my car and no issues so far and I live in NYC areas where the roads are one of the worst..
Old 09-30-2009, 02:45 PM
Gene's Avatar
124's seem to have a pretty good history of cracking....a quick search will show you just ow many times it's been discussed....
Old 10-01-2009, 08:48 AM
Kzang's Avatar
Yeah I actually read a lot that the 124's were pretty bad.. however, so far I've been lucky I guess.
Old 10-01-2009, 08:52 PM
gwf545's Avatar
My Ride: 2015 535D M Sport
I have had cracks in two of my rims. One I replaced for nearly $500 and the other I got repaired for $250. There are lots of rim repair shops that safely fix rim dents and cracks. I am not sure of the cause since I am pretty sure that i never hit anything hard enough to cause a crack. I often wonder if the rims were weakend or initially cracked during runflat removal and replacement. I watched them being changed once and it was an ugly site. The sidewalls are very stiff and make it very difficult to remove and install the tires. The tech had to use a lot more force than I think the alloy wheels were built to withstand. The leaks / cracks did not show up for quite some time afterward, but I gotta wonder if it just took that long for the cracks to grow large enough to leak air. I run non-runflats now and hope that's the end of cracked rims for me.
derooster
09-22-2016 07:30 AM
PelicanParts.com
Meet & Greet Discussion
10-16-2015 03:07 PM
LILBZ3
09-27-2015 08:06 PM
Gregm
09-17-2015 03:57 AM
lcc014
DIY: Do It Yourself
09-10-2015 05:57 AM
Quick Reply: Any suggestions
