Any one have 20" on sport suspension? Will this offset work?
My Ride: 525i
Hi everyone I have a 2004 525i with sport suspension. I'm looking into buying some 20" bbs lm reps for it. The set I found are 20x8.5 up front and 20x10 in the rear. Offsets are +20 for front and rear. Would this setup work for my car? Also what tire size will be best? Will it affect my gas milage or speedometer? Thanks everyone
My Ride: 2004 BMW 545i sport package with Mteck & M5 Rims Mpower
Don't know if it'll fit put what I do know is you are going to burn more gas cause rims are heavier . So you do,the math .
They will fit however you might need to run a 5mm spacer up front which is not a big deal. You will want to run 245/30-20 up front and either 275/30-20 or 285/25-20 in the rear. These tires will keep your overall rolling diameter similar to stock so your speedo will not be affect much. Mileage will be affected depending on how much heavier or lighter the wheel/tire combo you go with. In the end it shouldn't be to much of a difference since our stock wheels are lead weights anyways.
TexaZ3
05-06-2015 09:54 AM
