anti-trap message?
Old Jul 19, 2005 | 05:15 AM
arc1's Avatar
The little ! light is on and shows an anti-trap mesage. How do I clear this or is it a glitch? TIA
Old Jul 19, 2005 | 06:18 AM
FJPM's Avatar
My Ride: 535 D - to be delivered end Feb 2005 - color E08 - comfort seats - executive leather balck - 122 wheels - dynamic drive - active steering - pack luxe - tecnology pack - moon roof - 6CD player - hifi system - spare wheel - BT phone
I got it also a few eeks ago. It is probably due to high heat locked the window in its slider.
I could get rid of the message simply by turning the ingnition without pushing on the brake. The display showed the brake pedal symbol and it simply erased the previous message.
Old Jul 19, 2005 | 06:45 AM
ls78000's Avatar
My Ride: 530d (Jan 2005) premium pack, pro nav, steptronic
I also got it one month ago. After having made some testing on every window, I realized it was about the rear left window. The "fast lift" function was also disabled for this window.
I fixed it by lifting the window down and up using the rear left window switch (not from driver's door). Anti-trap and "fast lift" enabled again.
Never happened again.
Old Jul 19, 2005 | 09:45 AM
Frank310's Avatar
My Ride: 2005 545i Orient Blue/Auburn/Popular Wood Trim*Steptronic*NAV* Cold Weather Package*Rear Sunshades*Rear Side AirBags*Rear Heated Seats*Fold Down Rear Seats*Sport Package*Premium Sound*HUD*SAT Radio*
[snapback]150655[/snapback]
I got this message on my 3rd day of ownership. I turned key to position 1, held window switch closed for a few seconds, then open then closed. Make sure to hold at each position for a few seconds, this seems to reset everything and the message disappears. Had similar problem with the sunroof also, same type fix with sunroof switch.
Old Jul 19, 2005 | 11:33 PM
Yankee's Avatar
My Ride: E60 - 520i Dec 2004 built Previous 320i for 5 years
It is the controller/motor problem accordingly to our local dealer. It needs to be changed, if not, it would comes back again.
I had it and went back a few time and still it cam back afew days ago. I would be sending back to have the new revision controller/motor changed.
Old Jul 20, 2005 | 08:26 AM
stream's Avatar
Banned
Originally Posted by Yankee' date='Jul 20 2005, 12:33 AM
[quote name='arc1' date='Jul 19 2005, 08:15 AM']The little ! light is on and shows an anti-trap mesage. How do I clear this or is it a glitch? TIA
[snapback]151039[/snapback]
[/quote]
I had this on my drivers window, plus iy would go up partially and then reverse--they replaced the window drive--no problems now.
Old Jul 20, 2005 | 09:07 AM
johno535's Avatar
My Ride: E60 535d sport saloon M57 Titanium silver nav-pro, bluetooth, media pack, de-chromed, eletric sun roof, auto dim int, folding ext mirrors, auto dim int mirror, sport seats, alum cube interior trim, headlamp washers, bi Xenon, M-sport suspention, M steering wheel, M Aerodynamic bodystyling, M styling wheels, Black leather, Anthacite heading
I took the car back to bmw and they changed something in the rear door and now it is fine
Old Jul 20, 2005 | 10:15 AM
blacky's Avatar
Had the same message few days ago.
Was told by a guy in our local meet up that this problem can be solved by holding your window button up for two or three seconds longer. This will "Reboot" the anti-trap message and set it back to default..
I have tried it nad the message goes away after hold all four windews for few seconds.
Kinda like "Alt-Ctr-Del" for soft reboot on your PC windows.
Hope this helps..give it a try to see if it works for u .
Blacky
Originally Posted by johno535' date='Jul 21 2005, 01:07 AM
I took the car back to bmw and they changed something in the? rear door and now it is fine
[snapback]151174[/snapback]
jluzbet
Nov 7, 2015 01:25 PM
alexbaldy
Sep 28, 2015 12:28 PM
bimmerspeed
Sep 3, 2015 09:29 PM
bimmerspeed
Frequently Asked Questions
Sep 1, 2015 05:09 PM
fifthofjac
Aug 30, 2015 07:08 PM
