... Another Newb Question in tire pressure sensors
My Ride: 2004 545i / Orient Blue (I think) / Tan int / 116's Wheels / ... my favorite option, the HEATED steering wheel!
Previous cars retired:
2006 Corvette Z51, 2002 Corvette Coupe, 2002 Mustang, 1997 Maxima, 1994 Camry, 1990 Supra
None, and I mean none compare to this 545i. The 06 Corvette was faster, but not by much...
Ok Masters, here is another Newb question that needs answered.
I am thinking of doing a second set of "summer" rims and tires. Do I have to worry about tire pressure sensors or recalibration of the tire pressure monitoring system, or can I be lazy, switch them out, and do the recalibrate right through the iDrive section in the service tab?
Thanks, a newb patowan...
Sweet! That's what I was hoping for. Any issues with changing rim size?
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
No issues at all with upsizing wheels.
My Ride: G30 M550i
Model Year: 2018
One small thing to confirm -- what is the build date of your car? On cars built before around 3/2006, you'll be fine since there are no sensors installed in the wheels. You won't even have to keep the pressures the same, etc. as described above. You'll just reinitialize the FTM system through iDrive when you do your changeover. If your car was built after the 3/2006 date (I see it's a 545i from your avatar so I think you're okay), then you have sensors mounted in the wheels so you'll have to buy another set of sensors for your alternate setup...
