Another active steering and alternator issue
#21
My Ride: 545i sport
Found active steering malfunction cause: Broken wire at the X/Y14035 connector serving the "electric lock" part of the active steering gearbox.
#22
Check to c if u have a bmw or a after mkt battery. When it gets cold like this u get all kinds of codes when the battery is old. Check the date on the battery. I used to get codes and active steering codes when it got cold. N the summer I did not. So u probaly need a new battery. After changing mine this winter I have no codes.
#23
#24
My Ride: 545i sport
I had to yank the alternator, jack up left side of engine and remove engine mount to have any chance of getting to the electrical connector on the steering gear. Since I have the alternator out, it is going in for a rebuild: new voltage regulator and check the rectifier. Alt shops seems to think the rectifier could be bad (symptom: alt load/unload with noise). Anyway, if an alternator rebuild does not fix the problem, at least I can rule it out and have peace of mind that the alt is good for awhile. Battery is BMW label and I have no idea how old it is.
As a reminder: When alternator settles down, idle settles down (or vice versa).
#25
if you can get to the "alternator gasket" while you have all of that out of the way I'd do it. it's a $2 gasket but can cause a major oil leak, right onto the exhaust headers. real nice smokescreen. happened on our 745.
realoem link
realoem link
#26
My Ride: 545i sport
I already replaced "alternator gasket" last month...man what a PITA that was (it was leaking badly when I purchased car). Took alternator to alternator rebuild shop and they phoned to say alternator was toast...bad rectifier. Rectifier's are not available seperately, so I had to order reman. alternator.
#28
I have the same issues DavidF is facing. I fear the alternator may be part of the equation. I know my front valve covers are leaking, and I'm guessing that oil isn't doing any favors to the rest of the systems...
