Angel eyes for e60 LCI Halogen
My Ride: 520D 2008 E60
Hi there...
Can I ask if you change the hid kit yourself? I'm having similar headlight running on a H7 halogen and wonder if you could share the upgrade process if u were to do it yourself. Thanks....
Yes, I done the install my self, it's very easy.
I spent only 1h, I will take photos this WE to show you the install.
You plug red and black wires to the OEM H7 bulb socket, then this wire go to ballast input, then from the ballast outpout there is a harness (with anti-error) which goes to HID bulb.
All wire and harness have a specific connexion, so it's impossible to do a mistake.
I switched from H7 halogen to HID 6000k and the result is awesome, the light beam is very powerful.
Some pics
Before the mod
Some pics
Before the mod
wonderful! Do you need to remove the entire headlight in order to connect the socket? I can't seems to find the socket? I canonly remove the H7 bulb and that's it
Thanks...
Thanks...
no you have not to remove the headlight.
You have to remove the metalic socket from the bulb (The socket of the H7 bulb) and set it on the the HID bulb to allow it to connect in the original place.
Sorry for asking so many questions :0
Thanks...
Yes of course, you need specific ballasts which do not trigger error on the idrive.
In France i found only one vendor which sells the good ballasts.
http://xenonbryne.fr/boutique/hid-xe...m-ballast.html
socale39
09-05-2023 08:30 AM
Tsoup
15
12-20-2021 11:14 AM
rizwan1377
04-05-2015 05:22 PM
