Always starts on radio, not CD
I have a 2006, think its professional as iy has widescreen. If I am listening to the CD changer when I shut the car off, when I start it back up again, its switched to radio. Is there a way to set to stay on CD?
Engine: 3.0 B58; 3.0 M54
I would program the driver settings to see if that works first. Set everything up the way you want it then go through the memory save procedure. That's utilizing the M1/2 buttons on the side of the driver seat. If it doesn't work you can code it in but that process is probably out of your scope.
Using it at weekend, it was sporadic. Sometimes it started back on CD, other times on the radio.
