Almost out of fuel...
My Ride: 520d LCI, old engine, manual, black dakota, platingrau II, standard (242?) rims.
Here in Belgium, when you buy a car, it doesn't come with fuel ;-)
Hence, one has to drive to the nearest pump to fill up. In my case, I added 68 liters.
But I understand that someone has filled up even more...
Originally Posted by MacSid' post='468927' date='Sep 12 2007, 08:46 PM
You're absolutely right on this one. In addition to not getting the cooling from the fuel, the fuel pump will be ingesting some air as well, and this isn't good for its mechanics either.
Originally Posted by Adumbration' post='469324' date='Sep 13 2007, 11:44 PM
Air in the tires?
How did that custom come about?
I don't know how it came about. I'm Dutch and I've been living here for only a year and a half now. In the Netherlands one would get at least half a tankful upon delivery.
Of course it's no problem, but it's a bit odd when you get into your new car: the first thing you see on the dash is a warning sign.
Tow / Push / Pull
Originally Posted by aqkhan6us' post='469591' date='Sep 14 2007, 06:30 PM
How do you drive to the nearest gas station ?
Tow / Push / Pull
Tow / Push / Pull
There are examples of people that did not make it to the nearest gas station (although of course a normal dealer will make sure that that doesn't happen). In my case, I only had to drive 200 meters and put in exactly 68 liters:
My Ride: 2008 535xi / Platinum Grey / Black leather / Step Auto / Sport / Premium / Cold weather / 18" wheels / Logic 7 / Comfort / ipod / Navigation / Fold Down Rear Seats / Rear Airbags / Sirius SAT / Spoiler / Extended Clear bra / Bluetooth. (Previously owned a 2002 sport 525I Loaded).
On order: 535xi Platnium Grey with Black interior, Step Auto, Sports package, Premium package, Cold weather package, 18" wheels, Logic 7, Comfort access, ipod adapt, Navigation, Sat radio, Rear spoiler, Extended Clear coat bra.
Originally Posted by Rudy' post='468902' date='Sep 12 2007, 08:29 PM
I can't say exactly what's left in the tank after the zero reading but clearly there's something. Keep in mind that the countdown reading might jump from a single digit number like 5 or 6 straight to zero without showing 4, 3, 2, or 1 since it's calculated based on MPG which can fluctuate.
One thing to keep in mind -- running the car with little to no fuel in the tank can cause the fuel pump to run hot since I think the pump is submerged in the tank and is cooled naturally by the fuel that surrounds it. If you often run on empty, you might be shortening the life of the fuel pump...
Originally Posted by aqkhan6us' post='469775' date='Sep 15 2007, 03:04 PM
May be the gas pumps owned by the dealer directly or indirectly
some deal may be involved in Belgium between Dealers and Gas Pumps ?
