Airbag light HELP!
My Ride: 530i
Hello all,
A week ago a red airbag light appeared on my 06 530i while detailing the car with the engine off. The warning message is “Drivers Airbag Malfunction.” Upon reading the code with my Corsoft reader the error was due to “Undervoltage.” I was unable to detect a code with my Bavauto SR-SRS reader. I knew the car had battery problems as it frequently had low battery warnings and upon testing would not charge above above 65%. I replaced the battery today and programmed the battery. I attempted to clear the code however the code still remains. Any ideas?
My Ride: 535i XDrive M Sport Package
Model Year: 2011
If the battery charge falls below voltage required to activate the airbags, an airbag failure code will be generated. Recharging the battery will address the cause -- assuming the battery will hold the charge -- but will not clear the error code. When this happened to me (repair shop left car door open all night, with interior light on) I had to get BMW dealer to clear the code.
My Ride: E60 2006 sedan auto
The airbag code can also or sometimes refer to the seat belt
I know you suggested that the cause you believe was from cleaning?
I would check your codes again with respect to seatbelts
I think they begin with sbs codes
I hope this may help
TorchNBurn
03-27-2018 08:13 PM
Angelo6379
02-26-2012 04:06 PM
hks
06-12-2010 07:18 AM
w84me
10-24-2007 11:27 AM
