After wheel balancing, shake continues!!!
Old 04-16-2016, 08:24 AM
  #31
Lcajucom's Avatar
My Ride: 2008 528i
Originally Posted by DILLESTJAMZ
So im in this infamous +60mph Shake/vibration, i have replaced my thrust arm(Upper control arms) replaced my front passenger shock, put in new wheels (Style 95's 19x9,19x10 rear) they all have 7/32+ tread on all tires i believe the fronts are 12/32 treads... anyways, I've gotten all the wheel balanced... the guys put it on a lift this is another shop from where i usually take my e60 to since they do wheels and tires here... they put it on the lift everything checks out "really good and in great shape" all wheels were balanced again and i still have that vibration my steering wheel does not shake simply light vibration but the car shakes front passenger seat shakes... What is wrong guys? any suggestions?
I have the same issue guys,i balanced my tires 3x and still vibrating. I put back my factory rims back on and no shake what so ever. My next options are road force balance and allignment. Hope that will do the trick. Really hate to buy new tires when its only half a year old. Running on 285/25/20 w/lionhart tires.
Old 04-17-2016, 08:50 AM
  #32
Rvn10's Avatar
My Ride: E60 530xd
Although i did not read the full thread i believe that the solution to your problem is much more simple, I had the same problem twice before, and just like you i had my wheels balanced and checked for any loose ends, everything was fine but the vibration was still there...all you need to do is get the right center hub rings and the problem will be gone.
Old 04-17-2016, 09:19 AM
  #33
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
You're right. You haven't read through the whole thread. That was already suggested.
Old 04-17-2016, 03:26 PM
  #34
E60Japanese's Avatar
My Ride: E60 2006 sedan auto
I had a slight vibration when i bought my car around 130 Kph
I fitted new tires and it was still there
I fitted new bearings and discs and it was still there
I fitted new control arms and it was still there
I replaced the rear transmission rubber and center tailshaft bearing and ti went away
It is hard to say what is caursing yours but everyone has given some great advice
keep looking as we all have and youll find it
good luck
Nihilation
07-10-2022 11:32 AM
madein
06-06-2015 11:48 AM
asinner
05-06-2015 06:03 PM
Stranger12
04-05-2015 10:42 AM
08-12-2003 11:41 AM
Quick Reply: After wheel balancing, shake continues!!!
