After wheel balancing, shake continues!!!
Old 06-07-2015, 04:47 AM
DILLESTJAMZ's Avatar
My Ride: None
Model Year: 2012
Engine: N54
@jays545 you had the shake when you didn't step on the brake petal or once you stepped on the petal the shake went on
Old 06-12-2015, 05:19 PM
SNYPRUSMC's Avatar
My Ride: 2008 550i
Does the shaking reduce at all after the tires warm up?
Old 06-13-2015, 02:58 PM
JAYS545's Avatar
I had the shake when I hit the brakes around 50 miles a hr.and above.
Old 06-13-2015, 03:00 PM
550sport87's Avatar
My Ride: 08 550i sport. n62tu
Out of curiosity you don't have fixaflat in any of your tires do you? I've seen that stuff create all kinda of shaking.
Old 06-14-2015, 05:16 AM
My Ride: None
Model Year: 2012
Engine: N54
I have the shakes just accelerating above 60 mph, and no no fix flats that i know of
Old 06-17-2015, 11:10 AM
H F
H F's Avatar
My Ride: 2005 545
Originally Posted by DILLESTJAMZ
So im in this infamous +60mph Shake/vibration, i have replaced my thrust arm(Upper control arms) replaced my front passenger shock, put in new wheels (Style 95's 19x9,19x10 rear) they all have 7/32+ tread on all tires i believe the fronts are 12/32 treads... anyways, I've gotten all the wheel balanced... the guys put it on a lift this is another shop from where i usually take my e60 to since they do wheels and tires here... they put it on the lift everything checks out "really good and in great shape" all wheels were balanced again and i still have that vibration my steering wheel does not shake simply light vibration but the car shakes front passenger seat shakes... What is wrong guys? any suggestions?
Why did you only replace one shock ? I think its a good idea to do both sides to have an equal and balanced ride feel .. its recomended to replace in sets ..
Old 06-18-2015, 05:16 PM
JAYS545's Avatar
Check the tie rod as well.
Old 06-18-2015, 08:23 PM
My Ride: None
Model Year: 2012
Engine: N54
It was hard looking for the other "Sport M Strut" but i will be replacing my shocks with Megan Coilovers All around hopefully the shake will go away, As far as tie rods 2 Shops have said all my suspension components check out, they both said go for an alignment and get rid of the toe i am no looking forward to install the coilovers and then do the alignment
Old 06-19-2015, 08:14 AM
tomstin's Avatar
My Ride: 2004 525i
How old are the tires? Date code is on the side. I had a similar problem, bought from a retired gent who didn't drive it much. Tires were 6 years old but reasonable tread. Had them balanced twice before I checked the date code. New tires fixed the problem.
Old 06-21-2015, 08:56 AM
My Ride: None
Model Year: 2012
Engine: N54
I am considering new tires they make that thump whenever I'm reversing or make a sharp left or right turn under 10mph
Quick Reply: After wheel balancing, shake continues!!!
