Advice Needed: Brake Booster, Vacuum Pump Replace due to oil leakage.
06 550i, 80,000 miles lost bottom end braking capability.
Recall on the valve had been done.
'New' indy shop for me claims Brake Booster and Vacuum Pump plus gaskets needs to be done for around $1,800.00
What are your thoughts? I am reading some of the threads here that claim a seal replace might do the job?
Good News:
BMW covered the replacement of a brake booster, brake servo unit, seal, and bleeding of the brake system all at zero cost to me. Recall of valve covered this malfunction.
Things to note: I had the recall of the valve down a week before my issue so the SA had a solid reason to cover the repair under that recall.
*Indy shop stated I needed a vacuum pump replacement which BMW said I did not need. Can't say I am surprised there.
My Ride: 06 550i
Model Year: 06
My recall work was done about two years ago and I was told originally that it was not covered. I wonder should I try a different dealership or the same again?
Anyways thanks for the update.
socale39
09-05-2023 08:30 AM
thesalboy
04-08-2015 09:13 AM
mantraguy
03-09-2015 02:56 AM
