Adding NAV to an 07 550i pre-LCI
#21
Depends on what you get. Like I said, when I was looking at buying from bmwretrofit, the system came precoded and was 100% plug and play. I bought the components separately and coded it myself. It's also possible that the ccc you buy may already match your options. Unlikely though. Basically, when you install it everything will work, but your stereo might not sound right if your amp is different. Your heated seats might not show up in idrive. Things like CDC or iPod might not work right. So on and so on. The system will physically work with no coding at all though.
#22
#29
He had it correct. Maybe you were reading backwards? ![](https://5series.net/forums/public/style_emoticons/default/whistling.gif)
We've discussed this so much. If you want to live without some options like voice control, skip the microphone.Buy a CCC Profession Navigation, if it comes with the fan and fan harness great, if not, get a fan, get the 8.8"monitor.If you use SSS (progman) to code this you have to get the correct part# for you car or it will abort the retrofit. If not you can get any 8.8" monitor even from an X5, 6 series, 7 series and take out the screen and retrofit your current display case to fit (if you're handy enough with tools) and get yoruself a fakra gps cable (its magnetic) and route it behind the odometer behind the display about 12" away from CCC.http://www.ebay.com/...=item336b87f047 Hook it all up. If it works, great. If not, get yourself some tools and start coding the car. It's not hard just requires some reading. All of which is already here for you.
I use Progman quite often and these retrofits can be a PITA due to many variables. I guess I'd just recommend NCS.
I would only use Windows XP SP3 on any of these BMW tools.
My Audi / Volkswagen tools run fine on Windows 7 but I still use them on XP as well. I've gotten the BMW tools to work on Win 7 32 bit and worked great until that ONE time where I really needed it and it caused an issue even when in compatibility mode. XP all the way after that one.
#30
Nah I was wrong, I went back to correct the mistake.
