Adaptive headlights malfunction after swapping
Old Feb 23, 2024 | 11:56 AM
e60babyyy's Avatar
Probation Members
My Ride: BMW 528i
Default Adaptive headlights malfunction after swapping
i have a 2008 528i LCI with adaptive dynamic xenon lights and i recently bought two headlights (not in pairs because it’s cheaper)
They are OEM Hella headlights and i’m getting the adaptive headlight malfunction warning. i noticed the left headlight works fine all lights work and on the right all the lights work but no adaptive headlight movement.
is there coding required for it to function properly or can i just switch over the adaptive headlight control unit from my original set of headlights ?
if swapping out the control unit doesn’t work what would be my next step ?
if anyone does remote coding please let me know.
if not i’ll be willing to do it myself just need some steps
All help appreciated Thanks 🙏
Old Feb 24, 2024 | 08:25 AM
Dj530's Avatar
My Ride: 2006 530xi (One black & one grey) 2010 X5 35d 1974 BMW 3.0CS 2008 535i, 2009 335d, 2011 X5 35d, 2008 335i FBO
While these lights are new to you, you did not indicate if they are used or new. Posting scan codes would also help. Make sue plug on the right side is seated correctly with no bent pins. Try right headlight on left harness . . . . .
This-Rex
Jan 17, 2024 12:27 AM
ms32gojoe
Dec 5, 2016 07:26 PM
hks
Feb 8, 2010 09:29 AM
atlarep
DIY: Do It Yourself
Jan 21, 2010 06:54 PM
Memotronic
May 15, 2005 06:19 AM
