Adaptive Headlights
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
How do you check to see if the Adaptive Headlights are working properly?? By that I mean moving 15 degrees to the left and 15 degrees to the right.TIA
cheers
vern
cheers
vern
cheers
vern
cheers
vern
[snapback]165509[/snapback]
I thought I had a problem with mine due to lack of use recently (light until late here in the summer, did not have auto on engaged). What I did to check mine is find a dark road and switch on my high beams (Xenon, not halogen) and turned the wheel left and right. You should be able to see them track. IIRC you cannot get the lights to turn towards the left under low beam.
My Ride: E61 525iA Build 2004/08. "Safirschwartz Metallic". Navi Pro, Adaptive Headlights, Bi-Xenon, Panorama Sunroof etc... CIP 18.00.01 (No noticed bug)
cheers
vern
cheers
vern
Originally Posted by stafli' date='Aug 31 2005, 01:04 PM
[quote name='vern' date='Aug 31 2005, 02:31 PM']How do you check to see if the Adaptive Headlights are working properly?? By that I mean moving 15 degrees to the left and 15 degrees to the right.TIA
cheers
vern
cheers
vern
[snapback]165520[/snapback]
[/quote]Yes - the green light flashes if the system doesn't initialize properly... I presume it does a check to see if all the motion is ok. Mine have been fixed today (new headlamp) so hopefully the light will stop flashing!!!
My Ride: G30 M550i
Model Year: 2018
One thing to keep in mind while performing any visual testing: on a left-hand drive car, the lights will not move to the left if the car is standing still...
My Ride: 2002 325i - SOLD
2006 525i - PCD in August '05
1999 CVPI - My work car
Yep.. just got home and I tested them driving about 15mph. Slowly turned the steering wheel to the right on a curve, and sure enough they went to the right. Then I did the same to the left, but on a straightaway, so I had to get all the way on the right, and quickly turn the wheels to the left, and it adapted quickly!
Vman33
03-14-2022 04:43 AM
umnitza
11-25-2015 11:10 AM
Bogdan7
09-23-2015 11:40 AM
