Adaptive Headlight Failure
Old Jun 5, 2014 | 04:01 PM
rollsdc's Avatar
My Ride: 535xi
Default Adaptive Headlight Failure
I was wondering if anyone had an idea of what was wrong my 535xi it is throwing an Adaptive headlight failure I drive. I start the car I can see them leveling up and down and back and forth but after about 2 minutes it throws the error.
Old Jun 5, 2014 | 05:56 PM
Twindawg's Avatar
My Ride: 535i M Sport
Model Year: 2014
Engine: 3.0 I6 TwinTurbo
Possible that the headlight wiring is becoming brittle and beginning to break. This happened to my left front headlight. Everything works but my daytime running light on the left and the highbeam bulb.
Old Jun 5, 2014 | 09:21 PM
zach1328's Avatar
My Ride: 2008 535i
What about when you take a corner at night? Can you see the headlights turning around the corner with the car?
If so, its most likely just faulty wiring even though the adaptive headlights are still working. I'm guessing they still turn with the car around corners if they level in all directions when turning the car on.
Otherwise, it could be the control unit.
Old Jun 5, 2014 | 10:02 PM
rollsdc's Avatar
My Ride: 535xi
They don't turn when cornering only when i start the car. Lights work fine, just won't move after the fist couple minutes the car is on then it pops up with the adaptive lights failure
Old Jun 6, 2014 | 08:41 AM
paul-g's Avatar
well seems like the problem is there, now does it come on when just using the normal mode with out the adaptive head lights? i'd assume so as it sees it being bad. normal mode is when you don't have it on auto if you weren't sure.
sounds like you need new headlight set-up $$$$$
Vman33
Mar 14, 2022 04:43 AM
umnitza
Nov 25, 2015 11:10 AM
Kewill0360
Sep 28, 2015 07:32 AM
EuropeanArtz
Sep 23, 2015 08:21 PM
Bogdan7
Sep 23, 2015 11:40 AM
