Active steering malfunction
My Ride: 545i
Hey so I have a 2004 bmw 545i 130,000km has heads up install in it
Getting active steering malfunction and some codes. The light stays on even after erasing codes
First time running codes I got
Active steering codes 614a, 612e
Dynamic stability codes 5f62, 5eac, 5e96, 5f7a, 5e60, 5f10
after I Deleted codes and got
Active steering 612e, 614a
Dynamic stability 5f62
The active steering module might have gotten when not 100% sure it did. There was water under the carpet but the module was dry. I tried to reset the wheel angle position in INPA but it will not work
Any suggestions would help greatly, don't want to start throwing parts at it and pay for programming and coding
Not sure if these pictures mean anything
Did i-drive throw a notice, such as dynamic malfunction? Have you checked the fluid level in the power steering reservoir?
My Ride: 545i
I checked the fluids first before anything wasn’t low but topped it off anyways
I removed the active steering module and all my carpet to make sure any condensation issue was addressed
so far that is all i have done, I have found a cheap module but don’t want to buy that if it’s not the issue
My Ride: 545i
My Ride: 545i
but now I’m having an adaptive headlight module issues can’t communicate with it even tried to replace it and can’t communicate
Probation Members
My Ride: 550i
Dsblk93gt
04-11-2013 11:53 AM
