5Series.net - Forums
-   -   Active Steering faulty (https://5series.net/forums/e60-discussion-2/active-steering-faulty-27717/)
MRF550i Jun 21, 2006 10:35 PM
HELP PLEASE. :unsure: :unsure:
This morning when i was pulling out of my garage, i got this message saying that "Active Steering Faulty"
I restarted the car a few times and the message would not dissapear.
Has anyone gotten this message before and if so how can i fix the fault???
BTW the car is brand new with 600Km on it
Thanks,
EBMCS03 Jun 22, 2006 06:27 AM
http://forums.e60.net/index.php?showtopic=27547
Fireplace Jun 22, 2006 06:57 AM
Thanks,
I had the same problem with my new car and it was diagnosed as computer glitch. Dealer reset the software and everything back to normal.
One way to tell is if the active steering still function normally, meaning no change in steering behavior, it is most likely a false alarm. I am pretty sure it's not a major problem. All the best.
markt540i Jun 22, 2006 07:17 AM
Mine started this about ten days ago. I have an appointment tomorrow to take mine in. The active steering definitely stops working with the steering going to an apparent fixed ratio...having to turn more than normal at slow speed. The feel is still the same. Sometimes, like if I have my wheel turned when the warning comes on, the wheel will line up wrong. In other words, while driving straight the wheel is turned toward say 10 o'clock.
I do miss active steering when it is not working.
JDN Jun 22, 2006 07:22 AM
I've had several fault messages, but none in active steering. None of the fault messages has ever proven to be a true fault. Some are slower to go away than others. I used to get that DSC fault a lot with the topsy vehicle in HUD for absolutlely no apparent reason (usually driving like and old man when it occurred :lol:). It always corrected itself and dealer could not find anything when I finally showed up for service. Gas cap was another that was slow to cure itself, but finally did.
MRF550i Jun 22, 2006 07:37 AM
I called the service center today and they said that the software need to be reset. They said that there is an update that need to be loaded for about 3 hours and the problem will go away. :think: :think:
By the way the active steering is not working, i can feel it when i drive.
I'll update you guys once i finish the reset.
