Acceleration hesitation issue
Old 09-21-2017, 03:49 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
NoQuarter might be right. Spark seams to be the issue with what you are describing. I can not speak on the coils because I have 165k on the dash and my original coils are good. Coils could cause the issue you are having but a code should be thrown. One or two maybe on their way out. If that is the case then all should be replaced. Me, I would wait until a code is thrown or troubleshoot the coils to make sure that is the issue. May I ask what type of plugs did you put in the car. If they aren't the right kind that could be an issue also. I see a lot of people buy cheap ones thinking they will get 100k out of them when actually they are 30k plugs.
Old 09-22-2017, 05:02 AM
NoQuarter's Avatar
Engine: N54
My comment was just a generalization - not specific to this particular problem necessarily.
At 150,000 on the coils, he won't be disappointed replacing them regardless if it solves this particular problem or not.
Ageing coils have an affect on the performance regardless of whether it is bad enough to cause a code.
Old 09-22-2017, 12:49 PM
Razzy530's Avatar
My Ride: 2007 E60 530i 6 Speed Silver Gray
Engine: N52
Originally Posted by NoQuarter
You won't be disappointed with new coils.
i figured that. Maybe its time
Old 09-22-2017, 12:51 PM
Razzy530's Avatar
Engine: N52
The BMW dealer installed the plugs at 100K. So the plugs arent the issue. Im also thinking if its the coils than i should be getting a code/cel. Right?
Old 09-22-2017, 02:55 PM
NoQuarter's Avatar
Engine: N54
This is a tricky issue. Bad enough to cause a code and bad enough to affect performance are 2 different levels.
I weak spark is still a spark. The cylinder still fires.... just loses some of its mojo, leaving someone disappointed.
Old 09-26-2017, 02:26 AM
buddy's Avatar
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
Thanks from my research that is what i had come up with only turbo engines come up when i search but wanted confirmation, like i stated every thing has been replaced or tested that i can think of even dealer cant seem to fix, next options wanted
Old 09-28-2017, 06:59 AM
Razzy530's Avatar
Engine: N52
ordered a set of ignition coils. Original BMW parts. Will attempt DIY WIll update next week after install whether im still having this issue.
Old 09-28-2017, 07:38 AM
Model Year: 05 530i
Engine: 3.0 M54
Hopefully that fixes your issue. What you hope it is not is an injector going bad. What type of fuel do you use.
Old 09-28-2017, 08:40 AM
Razzy530's Avatar
Engine: N52
always premium 93 "top tier" rated fuels. And i use Lubro Moly German additives as well
Old 09-28-2017, 04:40 PM
Model Year: 05 530i
Engine: 3.0 M54
Ok just checking. Some people go 89 and we wouldn't know unless they tell us. I use the same additive alternating with red line
Quick Reply: Acceleration hesitation issue
