acc power source
Hi there
i am wondering if anyone here know where I can get the acc wire inside the car.
I am after a source which will provide 12v power ONLY WHEN the car is started. Tried the wires behind the headunit but most wires has power after I open the door. Any help will be great.
I assume you have the power outlet under the passenger footwell/glovebox. You can drop this panel and take the 12v from there. The wires are of a better size. I don't recommend pulling it from some of the other smaller wires unless you are only powering a small item.
Engine: N54
Best place to get power, easy to do and lots of amps available. View my DIY threads I think I have a pic in one of them.
i was going to get the power from cigarette lighter but I cant get to the back of it....
passenger footwell/glovebox? where about? I try the CD changer but it is on most of the time even the car is off for some reason.
alienintelligence
09-07-2015 12:09 AM
Bank$hot530
07-12-2015 04:36 PM
