AC- Not cold enough
Old 08-12-2009 | 05:33 AM
BLooD's Avatar
thats if you have the advanced air con., the normal auto air con. only allows changing it from warm - normal - cold and thats it.
Old 08-12-2009 | 05:54 AM
porsche911targa's Avatar
Originally Posted by Bklyn545i' post='972362' date='Aug 11 2009, 01:53 PM
Has anyone else had this complaint? Is it just my car (04-545i) or is there something I can do to fix this problem?
My complaint is quite the opposite; I find the AC too cold. Thanks to Rizbel for posting the instructions on how to adjust the intensity of the AC. I will set mine on medium or even soft, if need be.
Old 08-12-2009 | 12:00 PM
Ghostteck's Avatar
My Ride: 2008 550i manual
Engine: V8
doesnt work for me i went to vehicle settings and i only have (steering wheel options/ FTM/ Audio/ Lock ) no climate control. now if i go on the imenu i have climate control there with the automatic programs and i have high med. low but that controls the amount of air coming out not the coldness. the coldness of the air i thought depends on the setting with the blue and red bars =p
Old 08-12-2009 | 12:07 PM
Brit_in_NJ's Avatar
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather. Mods: Carbon filter removed. M5 iDrive knob. Umnitza license plate LEDs. MP3 40% 3M tint ACS Anti-Roll(sway) bars RPI Scoop G-tech Pro RR CF Roundels CF Wheel caps
Originally Posted by Richard in NC' post='972875' date='Aug 11 2009, 08:25 PM
Make sure you have the center vent temp all the way to 4 blue bars. It certainly should be cold at that setting. Although in 90+ weather, it does take a while to get there. Its in the vent settings of the climate iDrive menus.
+1 If you forget to change this and have it set to the 4 red bars you are mixing hot air with the cold from the AC which doesn't do much to cool a 100+ degree interior temperature.
Old 08-12-2009 | 12:10 PM
Kzang's Avatar
Do you have climate control settings at all?
If you tilt your idrive knob to the left it should take you there and then you can make the necessary changes.
Old 08-12-2009 | 12:36 PM
Ghostteck's Avatar
Engine: V8
i have the climate control from there but not from vehicle settings when you enter the idrive menu, and the high only turns up the ac to full blast not the temp. of the air i have it set to the coldest right now and it works just takes longer to cool down than others cars i've had =p or it could be that i have a black car lol
Old 08-12-2009 | 04:56 PM
Richard in NC's Avatar
You should be able to go into the climate control menu and look for "vent settings" in the 2nd row tabs. Then move down and over to where the arrow is pointing to adjust. Change it to 4 blue bars.
Old 08-13-2009 | 05:10 AM
Ghostteck's Avatar
Engine: V8
Attachment 86931
that what i did thank you
Old 08-14-2009 | 07:45 PM
Memotronic's Avatar
I have the same problem and my car is also (04-545i). Started with low cooling and then not cooling only from (driver side). After checking with BMW dealer, they saying A/C evaporator is leaking and needs to be changed.
AC evaporator pic
andymax
05-20-2018 11:32 AM
PakiBeamer
12-09-2016 04:40 AM
bestofthebest
01-05-2016 07:47 PM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
benski
F10 Discussion
09-16-2015 07:10 PM
Quick Reply: AC- Not cold enough
