AC on by default
My Ride: 2006 Black Saphire Metallic 550i, tan leather, nav, heads up, comfort seats, front heated seats, premium sound, logic 7, comfort access.
The AC in my car is always on on ignition.
Is there a way to disable this function and turn it on manually whenever there is a need?
Thanks for your help,
My Ride: F02 LCI Individual
Model Year: 2013
It should be remembered by your key if it was on or off when you locked the car the last time.
If the A/C was on it will be on when you use the key the next time.
I think we beat this around once or twice before, but I thought we agreed that at least in US SPEC, if you had it pressed to OFF than after sleep mode it would revert to on in some form of full AUTO or some slight variation. But if you go out of AUTO into any manual individual settings such as AC off and set say the blower to minimum or any manual setting it would remain that way when restarted even after sleep mode.
My Ride: 2006 520d M-Sport / Silver Grey / Maple Wood / Black Dakota Leather / Heated Comfort Seats / Media Pack With Extended Voice Control / Space Saver Spare Wheel / Sun Protection Glass
To get arround this annoying characteristic I keep the blower speed on minimum. The disadvantage of the car's over-reliance on computer run systems is their apparent inability to retain any memory passed 30 mins. AC is an example, but so is heated seats.
umnitza
Nov 3, 2015 02:58 PM
boozooface
Bluetooth & Cell Phone Forum
Jul 29, 2015 06:56 AM
