AC Blowing Hot Air??
My Ride: 2008 535Xi
this started yesterday, and i had hopped it was just an issue because the car was parked outside more so than normal. the ac & max ac seem to blow hot / warm air. it actually seems like when i turn the ac off the air is cooler. any ideas? i have the car going in to check the anti-trap problem i had with the rear window this week, but if any one has experienced this prior i'd appreciate any help / pointers. the car has less than 1500 miles too, which kind of makes me question the reliability
My Ride: 2007 Sapphire Black Metallic 525i. Beige Dakota Leather, Premium package, bluetooth, BMW Assist, Xenon adaptive lights, Sirius radio
did u check ur climate control through i-drive.enter the climate area. there, u should see a character with bars(1,2,3,4 bars, depends) they should have the color blue and not red.
as for the anti-trap, i see you read the post about it. but still, even though if it worked, u should have it checked by the SA.
GL
GL
My Ride: 2008 535Xi
GL
GL
someone mentioned that when the battery was having a problem the AC and other things would go into sleep mode, what are the other things? as far as i can tell everything else is working without problems.
try just pressing the button MAX.it should light up the FROST button and CYCLING button and the MAX button.IF THAT DOESNT WORK.
best thing to do is head to the SA and COMPLAIN
GL
GL
My Ride: 2008 535Xi
GL
GL
Originally Posted by PhilPGHE60' post='622838' date='Jul 13 2008, 04:55 PM
i tried that too, i'll be calling my SA tomorrow. really gives me a good feeling that less than 1500 miles and it already has a fairly major problem.
There might be a problem with compressor or low and preon gas charge.
Take it to the dealer and let them check it. It happend to me and they replaced a part and recharged the system
well tried my best helping u out. it may be a faulty compressor or low in gas.
anyways, GL and keep us posted on ur updates, that way we can all learn of these symptoms
im having the same problem with my 05 525i...i bought the car used and it is no longer under warranty. a couple months ago i tried installing a sound sysmem which messed with the electricals in the back stock amp..im hoping that has nothing to do with it. although my sound system did have problems and now ive taken the sub and amps out but left the wiring in there. my ac's been blowing off hot air for about a month now but i havent taken the time to check it out..havent found a real solution and dont know if i wanna dish out a large amt to get it fixed.
