Abti-Trap function on window
So I took my E60 in for a anti-trap error in the rear passenger window the other day. The window was working fine( rolled up & down) but I would get a error once in a while. The SA told me that they couldnt replicate it, and ended up upgrading the idrive to 18.1. So I went to pick up my car after 2 days and soon as I get in the error pops up in the idrive screen. So I get the SA and he gets his tech who worked on the car and he was dumbfounded
. After 1 hour they said the rear motor was loosing its memory and they orderd a new motor for replacment and started a PUMA case beacuse this is the first time they saw this. They did mention that the fronts windows are know for this kind of issue but not the rear windows. Will keep you guys updated...
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
My Ride: 2006 525i Silver Gray/Auto/Prem/Xenon/Nav/Sirius
Hey Nolan,
I see you're in Encino... which service center do you use?
Originally Posted by Nolan222' date='Jul 29 2005, 08:23 AM
So I took my E60 in for a anti-trap error in the rear passenger window the other day. The window was working fine( rolled up & down) but I would get a error once in a while. The SA told me that they couldnt replicate it, and ended up upgrading the idrive to 18.1. So I went to pick up my car after 2 days and soon as I get in the error pops up in the idrive screen. So I get the SA and he gets his tech who worked on the car and he was dumbfounded?
[snapback]154330[/snapback]
I bought my car from Center on Van Nuys but they suck. I use Rusnak in Thousand Oaks. They dont give me the run round and take care me. My S.A. Joe is the "man" there.
Originally Posted by Vitacura' date='Jul 29 2005, 11:44 AM
Wow.. at least you caught it before you left! Hope its a painless fix!
[snapback]154349[/snapback]
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
My Ride: '04 530i. titanium gray with gray interior, premium package, sirius radio
Originally Posted by DINAN530i' date='Jul 29 2005, 09:49 AM
[quote name='Vitacura' date='Jul 29 2005, 11:44 AM']Wow.. at least you caught it before you left! Hope its a painless fix!
[snapback]154352[/snapback]
[/quote]I live in Sherman Oaks and take my '04 530 to Beverly Hills BMW. I had the same problem with the anti-trap on the right rear window. Instead of doing a software upgrade, they replaced the motor in the window and it has been working fine ever since. As an aside, when they took the door panel off to replace the motor, they broke the wood trim. Part was ordered and replaced.
I've had this problem since day one. The local dealer dealt with is a couple of times but it keeps coming back. Now...... I just don't bother anymore because it always disappears the moment you restart.
Originally Posted by Blackonblackonblack' date='Jul 30 2005, 12:19 AM
Do you mean that your window, when being closed, inadvertently opens with no obstructions?? My front right window does this sometimes.
[snapback]154534[/snapback]
However, there was once when I used the key to wind up the windows and the driver's window kept opening up halfway.(after closing) Reported the matter and the dealer changed a new motor for me. It now operates like it should.
