6MT Tech: Gears Grinding?
Old Aug 30, 2010 | 09:33 PM
silvergray5456spd's Avatar
I came across something that doesn't seem right. Tonight on the highway, there was someone driving in front of me that was swerving quite a bit. So I wanted to pass them just incase if they were driving under the influence or something. I was doing about 70-75 mph, I fully depressed the clutch and I moved the shifter from 6th to 3rd (Don't worry, I rev match my shifts). As I'm pushing the gear shifter into 3rd, all of a sudden, the gears start grinding. This is with the clutch fully depressed. I tried it a few time and the problem persisted. Under 70 mph, it works fine. I even sped up to 80-85 mph to see if it still did it and it did. Is there something going wrong? I've never had this happen to me in any of the MT cars I've ever driven.
Old Aug 31, 2010 | 03:28 AM
Krozi's Avatar
How many miles on the car? Maybe a tranny fluid flush is in order?
Old Aug 31, 2010 | 05:28 AM
545felix's Avatar
My Ride: 05 545/6
either you need to bleed/flush your clutch hydraulic line or something is wrong with your slave cylinder. mine gets a little crunchy about first gear sometimes, but only at a stop.
Old Aug 31, 2010 | 06:15 AM
I just clocked 47k yesterday. How long is the tranny fluid supposed to be good for?
I've noticed that too. When putting it in first gear, it does the same thing as yours. I just got the CDV delete a couple days ago. When I put it in, I'm going to have to bleed the lines anyways, so I can start from there. I just wasn't sure if it was a problem with the clutch disengaging properly or something.
Old Aug 31, 2010 | 06:27 AM
Krozi's Avatar
47k is nothing....yea just try bleeding and then tranny flush if that doesn't fix it..
Old Aug 31, 2010 | 09:32 AM
Fleainat's Avatar
My Ride: 2013 550i M Sport 6MT Alpine White, 2013 X5 50i M Sport Alpine White
This happened in one of my older cars and it was a bad slave cylinder. A common problem in manual cars, and not too expensive to replace...
Old Aug 31, 2010 | 10:21 AM
salaki's Avatar
My Ride: 05 545i 6MT
If you did CDV delete recently and prior to doing CDV, your car didn't have this issue then it's more than likely improperly fluid bleeding
(makes it look like bad Clutch Slave Cylinder going bad)
How did you bleed the CDV? Old school method? Pressure bleed?
Or did you pressure bleed from the bottom to the reservoir?
I tried old school method and I could not even get the clutch cylinder to bleed at all then I borrowed my friend's pressure bleed and it bleeds fine after that.
Good luck..
Old Aug 31, 2010 | 04:35 PM
I'm going to try both of those soon.
Thanks for the input. I'm going to look into it.
Good luck..
I haven't installed the CDV delete yet. Sorry if my post was a little misleading. I will put it in when I flush the tranny and bleed the hydraulic line.
Old Aug 31, 2010 | 06:43 PM
TexaZ3's Avatar
Do a fluid flush, and bleed your slave real well. Your clutch is not fully disengaging for some reason, most likely because of the slave.
Might be worn pressure plate as well, but unlikely.
Old Sep 2, 2010 | 05:51 AM
I just spoke with my friend who is very knowledgeable about BMWs. He said most likely the syncros are shot. Looks like I'm going to have to drop the trans when I put it away for the winter. I'll just have to take it easy for the next couple months.
