6 Spd Manual Shifting Problems
My Ride: 2004 530i, 6spd manual, titanium silver/black, sport, active steering, Logic 7, adaptive headlights, cold weather, 35% all around/20% back.
I have a 2004 5 series with the 6 spd manual. In 1st, 2nd and 3rd gear if the engine hits 4000 RPM or higher the engine shutters and the car lurches. I took it to the dealer and they duplicated the problem (not hard as it happens every time), however they didn't have a fix. Their only suggestion was to only use Chevron gas, which I thought was a joke. However, desperate for any fix I tried this for a few months with no noticeable improvement. Has anyone else experience this with their manuals?
I also have a 2004 525i 6 sp manual.
I am not exactly sure what your concern is. Are u saying that after 4000 rpm in 1,2,3 gear, the car hesitates to accelerate? or r u experiencing some pause and all of sudden the car just jumps out?
Since mine is a 525, I never expected too much power from it, but my car feels pretty smooth in all gears in all rpm.
My E60 had a similar problem just before I traded it for my E61. There is a SIB out there apparently involving programming of the DME that addresses this issue in the 04 models.
The clutch is not as smooth as it was once, dont know why, a mechanic said that there could be an air bubble
rj
not with a BMW, but I had a VW Jetta 2 with the 16 valve engine and I had something that sounds very similar. I was also told it was bad gas, put in some injector cleaner and stuck to a major brand and it went away within a few tanks. I can't remember if I also changed the fuel filter for sure, but I believe I did.
When this was happening my car literally felt like it was going to shake apart. It does sound similar to what you're describing (perhaps insufficient fuel or air).
My Ride: '04 545iS 6 spd, bought new via eBay, 11/05; Blk/Gry, Cold, L7, PDC, BMW Rear seatcover for pets.
First "Bumwa" was a new 1971 2002. High performance 5s since 1987. Beamer motorcycles too, currently on an 07 BMW K1200 GT; also a Moto Guzzi 1000 SP III.
My Ride: 2005 BMW 545i / Black Sapphire Metallic / 6spd. manual / Sports package
I have a '05 545i manual and this has never happened to me...Your dealer telling you about Chevron is of course a bunch of typical BS that they try and throw at you.
Since you're in SoCal, I can recommend taking it to two independent BMW specific repair shops that I always use that are very highly respected and VERY fair priced. One is the M-Shop located in L.A. and the other is SouthBay Independent in Gardena. Both have BMW master mechanics and are very honest people. I go to SouthBay Independent since it's sorta close to where I reside.
Mihainede85
Mar 11, 2015 09:45 PM
