550i or M5
Old 07-11-2009, 05:57 PM
migs1969's Avatar
My Ride: M5 2007
Post
Been a member for a while now but a silent one though. Thanks for sharing whatever you know about your ride. Maintenance wise, how much difference with 550 vs m5 after the warranty of course. Thanks for the help
Old 07-11-2009, 06:00 PM
kaiten408's Avatar
My Ride: I have an 05 545i. It's a manual with a few options. This is my first BMW but I don't know how I'll ever be able to switch to something else.
Well oil for non-m cars is about $6-7 a quart. For M cars it's about $14-15 a quart.
If that gives you any kind of indication of what the rest of the maintenance is going to be like and you are comfortable with that, then I say go for it. After all, it is the ULTIMATE driving machine
Old 07-11-2009, 06:17 PM
dbae1978's Avatar
all m vehicles require more maintenance than the non-m cars.
Old 07-11-2009, 06:19 PM
miguex's Avatar
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
not just OIL.... GAS too.... M5 is guzzler and you will have to fill much more often.....
but M5 is a monster and 550i is a beast.
IMO get M5 if the gas is not the factor! and you live once!
Old 07-11-2009, 08:06 PM
C's Bimmer's Avatar
Get the M5. The cost difference is minimal when we talk about cars in this price range.
Old 07-11-2009, 08:20 PM
radzM's Avatar
if you can afford it, get the M5!
Old 07-11-2009, 10:04 PM
BulldogE60's Avatar
^^^ agreed. Also, C's is correct, if you are talking about a M5 gas and maintenance shouldn't be a problem.
Old 07-11-2009, 10:26 PM
BMWPower06's Avatar
My Ride: E60 BMW ///M5 V10
love my M5
Old 07-12-2009, 12:23 AM
DD_545i's Avatar
I doubt I'll ever go M5 again. I'm certainly glad I've done it once. It was a blast. Same deal with an RS6+ (510bhp). These machines are phenomenal. The trouble is that the difference between them and something like a 545/550 is all at the top end of the performance curve. What I mean by that is that you only see how much faster an M5 is compared to a 545/550 in, for example, a 0-60 test, if you're flat to the floor on 100% throttle and have a good traction surface. Now I'm one that always accelerates hard away from the traffic lights (nobody's ever kept up with me yet, although I've never actually properly had a race away from the lights, it's just normal driving and nobody ever kept up). I do find that I'm only using between 50% and 80% of throttle even then.
Same applies at high speed, it's not just sprints. Unless you're hitting 100% throttle for long periods (more than 10 seconds) you're just not going to be using that extra M5 performance. Even here in Germany on the Autobahns, most of the time I'd probably keep up with an M5 quite nicely simply because there's just not enough opportunity to use that extra performance advantage for long enough for it to make a significant difference.
I could have gone for an M5 or a 550i last october when I was car shopping but instead I went for this 545i and with 333bhp and 5.7s 0-60 I'm very happy. No desire for a sprintbooster or a remap yet. A 535d would have been enough performance even, but the 545i is a lot better up in the 120mph+ range.
Old 07-12-2009, 12:34 AM
forumballer's Avatar
My Ride: 2006 550i Black Sapphire
thats a good thought but i definitely think a lot of people like that extra boost in lower gears. i have a 550 and my dad has an e63 (basically same performance as m5)
and the e63 is way more fun to stomp on at the light. passing on the freeway at higher speeds they feel fairly similar though...
Quick Reply: 550i or M5
