550i Engine at Idle Noise
My Ride: 2006 BMW 550i
) All new BMW's require synthetic. As far as weight, only certain production dates of M3's and M5's require the use of Castrol TWS 10w-60.
2) The Factory BMW Synth 5w-30 is a version of Castrol TXT Softect sold overseas. A few important things about the BMW oil a) it is a Group III hydrocracked oil which cannot be called synthetic in Europe, b) it is a heavy 30 weight (30 weight can run from 9.3-12.5cst@100c, the BMW oil is about 12.2cst), c) it is a ACEA A3 oil which means that it is approved for longer change intervals and has a HTHS (High Tempurature High Shear) measured at 150c of greater than 3.5.
3) In the US, the only Group IV PAO Synthetics that are available are 1) Mobil 1, 2) Amsoil (but not the Xl-7500), 3) Royal Purple, and 4) German Castrol 0w-30 (it has the red label and says on the back, "Made in Germany). Redline is a Group V PolyEster based oil. All other Castrol, Quaker State, Pennzoil, Valvoline "synthetics" are a Group III hydrocracked oil. It is debated how much better Group IV base oils are than group III, but generally they are considered better.
4) When looking for oil for any BMW that does not require Castrol TWS 10w-60, you want to purchase an oil that has either/both of the following ratings, a) ACEA A3, or b) BMW LL-98 or LL-01.
5) Note that Mobil 1 0w-30, 5w-30, and 10w-30 are NOT ACEA A3 or BMW LL approved oils. This is because they all are thin 30 weight oils (approximately 9.8-10 CST@ 100c) and have HTHS of approximately 3.1. Mobil 1 0w-40 and 15w-50 are A3 rated and the Ow-40 is BMW LL-01 approved. For 99% of climates and users 0w-40 or 5w-40 is the appropriate grade. There are some 0w-30 and 5w-30 oils (like the BMW 5w-30) that are forumlated on the heavier end of the 30 weight scale and are accordingly rated A3. These oils will work well also. LOOK FOR THAT ACEA A3 rating. If the oil doesn't have it, pass on it.
6) Some people seem confused about how oil thickness is measured. The first number (0W, 5w, 10w, 15w, etc) is a measurement of how thick the oil is at tempuratures of -35c- -20c (depends on the grade). The lower this first number the thinner the oil is at LOW tempuratures. The second number (30, 40, 50) refers to oil thickness at 100c (operating tempurature). 30 weight can be from 9.3-12.5 cst, 40 weight from 12.6-16.2 cst, 50 weight from 16.3-22cst (approximate). So you can have two oils, one called a 5w-30 (i.e. bmw oil) another 0w-40 (Mobil 1) that are very similar thicknesses at operating tempurature. Compare this to Mobil 1 Xw-30 which is close to a 20 weight oil at 100c. For more information here is a link with exact numbers http://www.bobistheoilguy.com/visc.html
7) BMW's recommended interval of 12,000-15,000 miles is to long. Used oil analysis has shown the BMW oil is generally depleted at 10,000 miles. Running it longer results in excess wear. It is highly recommended that you change your oil once between each BMW recommended interval (approx 7000-7500 miles). If you want to run your oil the BMW recommended interval, I would suggest that you use Mobil 1 0w-40 or Amsoil 5w-40 and change the oil filter at 7500 miles. I would encourage a full oil change at 7500 if you want your engine to last.
8) If you want to spend a few hours learning about oil, go to bobistheoilguy.com
My Ride: 2005 545i Sport 6 speed Manual
whoa!!! so mobil syn 10-30 or 15-50 is not ok to use in my 545? i thought all those 0 and 5 weight oils were recommended just for energy saving since they require less energy to shear. because of that i feel like they are not as likely to keep metal away from metal so i use mobil 15-50.
am i fuct?
am i fuct?
First off, I am not a certified BWW mechanic.
I assume you're referring to the ticking sound? If so, the ticking sounds seems pretty distinguished. I have been an owner of my 07 550i since it had 15000 miles on it, and it has had the same ticking sound since I took ownership (22000 miles ago), though I am unsure if it is slightly less distinguished or not than yours...hard to tell without putting our cars side by side.
So you know, I've wondered about the ticking sound coming from my engine as well. Any other 550i owners have the same engine sounds?
The guys on another board seem to thing it does not sound right. I searched youtube for some BMW v8 videos and came across an X5 V8 and a 650CI (same engine as ours) and neither had the same amount pinging mine does. Just gives me some ammo for the dealership.
My Ride: 2008 550i Sport (6-speed)
You guys are scaring me. Does this ticking sound occur when the engine is cold, warm or all the time? I'm going to go out and listen to mine. I've read about stories from 545i owners and it seems the result was either a $16k bill or a new engine.
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
It sounds similar to the 545i ticking sounds posted on the forums. I have looked at several videos of the 650 and X5 4.4 and they do not have the ticking sound. I am off to the dealer with a list of 10 items, with this being the most serious. Thank god I bought the 6/100 Platinum Extended Warranty just in case.
